security warning should I be concerned
zedingrove
When login to forum I get a warning do i want to continue? untrusted certified on my phone
10 REPLIES 10
bobpullen
Fixes: 316
Re: security warning should I be concerned
Do you mean untrusted certificate? What phone do you have? Are you able to provide a screengrab?
zedingrove
OK screen shot below on a Samsung GT-I9000 or S1
Oldjim
Resting Legend
Fixes: 63
That is Samsung this is what Firefox gives
zedingrove
That is totally different to what I get when I view details.... And it has nothing to do with Samsung as it also does it a Motorola. Has nothing to do with make but Google Android browser as in Opera mobile don't get a warning.
prichardson
Zedingrove,
Are you able to provide a shot from the view details?
I have located something that may prompt this, but it has nothing to do with the certificate. I'm wondering if it is partially misleading message from the phone with the problem not actually being the cert itself.
zedingrove
OK first only comes up when going to login page and selecting cancel will close diag box just like OK
RPMozley
Fixes: 13
Could that certificate be for an advert?  Huh
That's RPM to you!!
bobpullen
Fixes: 316
I notice you mentioned logging into the forum initially however the screengrabs you've provided actually show the Member Centre/main website? Googling adnxs.com suggests a tracking organisation of some sort but AFAIK any adverts served by our website are internally hosted?
I can't replicate the problem using the stock browser on a Samsung  GT-i9100 S2 (running a custom ICS build v4.03).
zedingrove
Hey Bob, sorry it is the way I write, From google search of plus.net scroll down to member centre and select.
Also you are using PN over WiFi and not 3g, though when I try to access over 3g it is reported that page has moved and does not exist.
But it must be member centre as all other links you don't get warning.
bobpullen
Fixes: 316
Quote from: ZedinGrove
Done that.
I've tried it on both 3G and wi-fi and I don't get the warning with either (even when navigating to the site via Google search as above). I could access the link fine over 3G too.
