post not showing
sjptd
post not showing
Could someone look at my post Reply#6 in http://community.plus.net/forum/index.php/topic,140267.msg1237394.html#msg1237394
For me anyway it does not display, because there is a 'display:none' in the HTML
[tt]<div class="post" id="msg_1237394" style="display: none !important;">
                                                        They seem to have introduced a minimum zoom level for the street view tool to work (on my version anyway).<br><br>Odd, my version shows blue roads at all zoom levels. &nbsp;I think is the new one; it say "Welcome to the new Google Maps". &nbsp; &nbsp;By the time I can see the entire UK, dragging the man makes it all go blue except for some patches in the highlands.
                        <div class="smalltext" id="modified_1237394">
                    </div>
                        <div class="report smalltext"><img src="http://community.plus.net/forum/Themes/plusnet-brand-refresh/images/icons/modify_inline.gif" alt="" align="right" id="modify_button_1237394" style="cursor: pointer;" onclick="modify_msg('1237394', 'd52b1eaeb93bbcc2b340300287f7f7b4')">
                        </div></div>[/tt]
2 REPLIES 2
Fixes: 1,495
Re: post not showing
i can see both replies here without issue.
sjptd
Thankyou for looking: I should have looked in another browser.  A deeper inspection has shown that it is my ad blocker: uBlock Origin causing the problem.  Something they call 'Cosmetic Filtering'
