emails posts
petlew
emails posts
At some point in the forums change-over, I (assume) I must have selected somewhere to receive copies of posts sent to my email. I'm sure many members actually like this feature. I'm fed up with it already.
How do I turn this off?
4 REPLIES 4
Mayfly
All Star
Re: emails posts
I assume you mean you are subscribed to threads?
I think it must be a default setting because I got fed up of it too. I went to my name top right and clicked my subscriptions and unchecked all. Not sure if that's what needs to be done - time will tell.
Mayfly
All Star
Re: emails posts
Well that dosn't seem to work as I am still getting emails.
rongtw
Fixes: 12
Re: emails posts
I have mentioned this Before , Emails are set ON as default Ticked_off
Ok some like it , but like mayfly i think its wrong , OFF should be default and it you then want to recive emails you can set it up  after
I evtually forund the settings with Anotherones help Wink
w23
Fixes: 4
Re: emails posts
@petlew,
https://community.plus.net/t5/user/myprofilepage/tab/user-subscriptions:notification-settings will allow you to select which, if any, notifications you receive.  There has been discussion about the defaults and it was decided that more information was better than less and it's easier for experienced users to turn off notifications than for the inexpreienced to turn them on (that was the gist anyway).
Hope that helps. Smiley
Call me 'w23'
