edit a post with adding # sign and a number together
- Feedback
- Community Site Feedback
- edit a post with adding # sign and a number togeth...
on
09-06-2016
3:53 PM
- last edited on
10-06-2016
11:03 AM
by
this test line with have a number at end once I edit it and if it bugs, it will popup a new window
edit: well it bugged again, attached is what happens if I try to edit a post with eg a ticket number with a hash at front, so # 12345 without the space will force that page every time
Moderator's note by Adie (Dvorak) removed inappropriate tag.
Re: edit a post with adding # sign and a number together
09-06-2016 6:01 PM - edited 09-06-2016 6:03 PM
this test line with have a number at end once I edit it and if it bugs, it will popup a new window #1234
Testing using FF47.0
EDIT: It worked. for me?
10-06-2016 7:21 AM
using waterfox 46.0.1
10-06-2016 9:04 AM
Having a hash and number together will not cause this issue. The authentication error seems to happen at random with no rhyme or reason. It looks like this might not be an issue with the browser after all.
@LouisaMartin, can you feedback the authentication/secure connection bug with a link to this thread please?
10-06-2016 10:02 AM
Hallelujah! A number of us having been saying this for some time. It may well be true that the FF 'bug' caused or exacerbated some of the instances, but too many instances with other OS's and browsers.
M
10-06-2016 10:15 AM - edited 10-06-2016 10:16 AM
Doh!, good grief, after all this time, at last it sinks in !
You won't mind then if we say "TOLD YOU SO !"
If you would now listen and switch the site from HTTPS to HTTP, then we might start getting somewhere.
10-06-2016 10:16 AM
So why have I not seen the problem at all since rolling back to version 45 of my Waterfox browser ![]()
10-06-2016 10:49 AM
Could this is down to the way the editor / javascript used to post this very content interprets the # symbol, as it is used in HTML as a pseudo anchor tag, so it may well be confusing itself.
10-06-2016 10:51 AM
I said it 'might' be @Anonymous. It could have just been V46 of FF that was affected as they had changed some things with the browser in that version and have since applied updates to that component in FF47. This bug may not have been present in earlier versions of FF so its hard to tell what has changed since. I haven't received a single instance of the error since upgrading so far so...
10-06-2016 10:53 AM
@Anonymous, that is a possibility but the URL that is generated removes the hash when creating the URL for the thread. We are keeping our eye on this still anyway.
10-06-2016 10:58 AM
Fair enough @jaread83 it was worth a thought, so I'll move on item number #2 for a test.
10-06-2016 6:34 PM - edited 10-06-2016 6:35 PM
I've seen a few posts with ticket numbers of the format #12345 mentioned and none of the posters have reported an issue. Assuming I'm understanding the issue correctly, I'll add #67890 just to be sure.
14-06-2016 4:01 PM
Getting it on random posts now, not just any with a ticket number with or without a. But a work around i have found
I am typing it up in the rich text editor and if I can't preview it, it will bug out as described after hitting post. If after typing my reply or thread post and double checking with preview, I then switch to html it will then work in both preview and post
14-06-2016 4:05 PM
The more info we can gather the better chance we can have for finding out what's happening exactly.
14-06-2016 4:21 PM - edited 14-06-2016 4:25 PM
win7 Pro
Waterfox 46.0.1 with only ADblock 2.0 addon active
Yes I get a circle icon when it preview bugs but can't remember the message. Will see if I can trigger it editing this post
edit: caught it and all I tried to edit in was the # and number below
#12345678910
- Feedback
