Wrong timestamp
198kHz
Fixes: 42
Wrong timestamp
Just noticed this in the 'Home Phone' Topics list - at 2340 on 12 June:
BT technician (Retired)
20 REPLIES 20
Fixes: 251
Re: Wrong timestamp
That is also the time stamp I see on your post too.
An off the wall idea - can you please double check the date and time zone of your device, as the post above is also dated 11:48pm (later tonight)!!  That said your further post this morning has a time stamp of earlier today!
One would hope that the system uses server side time stamps - but this is a Lithium solution so there is some possibility it took a client side time! Wink
There is though also some possibility that one of the servers in their server farm has the wrong date!!!
198kHz
Fixes: 42
Re: Wrong timestamp
Thanks @Townman
All OK with my PC clock, time zone, DST setting etc.
I favour your latter suggestion - maybe the date is changing at 2300 instead of 0000.
198kHz
Fixes: 42
Re: Wrong timestamp
Messages #11 and #12 in this thread would appear to support that theory - the date changes between 10:59 and 11:02PM.
Same here - Messages #53 and #54.
MauriceC
Resting Legend
Fixes: 17
Re: Wrong timestamp
I'd hazard a guess that (at least) one of the servers has been set with an inconsistent time zone?
Re: Wrong timestamp
Well if that is the case then it implies it’s out of synch with the others and may well explain some of the other issues we see around here.
If the server is using a clock that’s an hour out to process timestamps for cookies, posts, sessions, etc then this could cause issues when they’re handled by another server using the correct time, and vice versa of course, by expiring a session it thinks is an hour ahead of its time.
MauriceC
Resting Legend
Fixes: 17
Re: Wrong timestamp
Could well be @Anonymous    Evil  it's surely a high contender!  We've got the haystack, just need to find the needle?
Fixes: 251
Re: Wrong timestamp
@JonoH
Can you please get Lithium to check out the theory here please?
JonoH
Fixes: 157
Re: Wrong timestamp
What exactly is the problem with the timestamps? they look fine to me.
Here are the two @198kHz linked to.
 Jono H
 Plusnet Community Manager
Fixes: 251
Re: Wrong timestamp
Posts 53 to 54 the DATE changes from 15 to 16 whilst the time advances a little 10pm to 11pm.
Go to page 2 of that topic and the time stamps are 16th at 7AM!
JonoH
Fixes: 157
Re: Wrong timestamp
That's raised and I've had a little fun with it as well Cheesy
Wait a minute Khrous, uh, are you telling me you built a time machine?
Description
We're experiencing inconsistent timestamps with the community attachment Timestamp2.png  shows the date changing at 11.01pm
You can see that here https://community.plus.net/t5/General-Chat/Your-Health-Records/td-p/1633629/page/4
Also https://community.plus.net/t5/General-Chat/Flaming-heck-What-happened/td-p/1647912
Shows message 11 timestamped at ‎15-06-2019 10:59 PM
Shows message 12 timestamped at 16-06-2019 11:02 PM
We've jumped a day here in 3 minutes and it's not 00:00
Shows message 13 timestamped at 16-06-2019 11:21 PM
Shows message 14 timestamped at 16-06-2019 11:21 PM
Shows message 15 timestamped at ‎16-06-2019 11:26 PM
Then somehow we go back in time
Shows message 16 timestamped at  16-06-2019 7:35 AM ‎
Shows message 16 timestamped at  16-06-2019 7:57 AM
Instance Production
URL(s) of Where Problem Occurs You can see that here https://community.plus.net/t5/General-Chat/Your-Health-Records/td-p/1633629/page/4<br><br><br>Also h...
Steps to Reproduce view links
Expected Behavior We shouldn't be able to go back in time.
Actual Behavior Turns out it's not just Marty Mcfly that can go back to the future.
Browser and OS All
Username, Roles, or Ranks All
 Jono H
Re: Wrong timestamp
That's odd @JonoH I seen that post an hour before you made it! Wink
Fixes: 251
Re: Wrong timestamp
@JonoH
That was a real tease!  I guess that when they come back saying they cannot reproduce it / identify the cause you can point them to the possibility of inconsistent date / time settings, be that different time zone / DST settings or simply pointing at a different time server.  It would not be the first time that such an issue has caused no end of mischief in multi platform solutions!!
Fixes: 251
Re: Wrong timestamp
@JonoH
@Gandalf has learnt to bend light - if support can find out what bit of the service he was connected to just before midnight it might help them focus their investigations...
Gandalf the Great bends time and lightGandalf the Great bends time and light
198kHz
Fixes: 42
Re: Wrong timestamp
It's a forum, Jim, but....  Wink
