User Subscriptions: Notification Settings Android Chrome
- Feedback
- Community Site Feedback
- Re: User Subscriptions: Notification Settings Andr...
11-06-2016 6:50 PM
User Subscriptions: Notification Settings needs two hits on each drop down to make a change. Android Chrome.
Re: User Subscriptions: Notification Settings Android Chrome
11-06-2016 7:01 PM
Hi there, could you be very precise about exactly what you are having to do please?
Also, I assume you are hitting 'Save' after the changes.
There are some odd things going on at the moment and I'm wondering if there's a bug (or more) resulting from any recent changes by Lithium.
11-06-2016 10:20 PM
For example, I want to set "" to Never
Select Never in drop-down box, nothing changes. Select Never in drop-down box again. Changes to Never.
13-06-2016 2:24 PM
Thanks, I wanted to be clear as to whether it was the arrow on the drop-down box or the option itself in the box. I was able to replicate it myself, but I hit the issue before then - just getting the Notification settings required it to be selected twice. Two different devices with the same version of Android gave different results on repeat testing ![]()
I will check again later, as I mentioned there were other oddities yesterday which I haven't yet repeat tested today and something did change over night.
- Feedback
