Upload folder full when trying to attach images to posts
- Feedback
- Community Site Feedback
- Upload folder full when trying to attach images to...
Re: Upload folder full when trying to attach images to posts
05-11-2015 12:43 PM
If I were you I'd check my system logs and see what information they contain, but I assume this has been done.
I would have thought that the upload dir should in fact a temp store so that anything uploaded was in effect quarantined, and after passing inspection would be moved to a permanent place and the uploaded file removed from disk. But hey what do I know!
05-11-2015 12:50 PM
05-11-2015 12:57 PM
05-11-2015 1:05 PM
05-11-2015 1:13 PM
05-11-2015 1:17 PM
LOL, just got:
Quote Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
while trying to post that.
05-11-2015 1:22 PM
If you can load a file of 11kB but not one of 55kB then yes you're maybe short of disk space. However, if you then do another upload of a 45kB file then this should fail, and repeating the process several times with an 11kB should result in no uploads being allowed.
But this does not appear to be happening, so someone needs to look at the device (/var/tmp/, /var/spool) used when reading the HTTP upload stream, I assume there is some configuration option somewhere to set this. It may well be that the temp stream device that is running out of space so not related to the physical size of the upload dir, which explains why all the setting still look sane.
05-11-2015 1:58 PM
Quote from: Anotherone Silly question, how can the Uploaded file be removed from disk if it's to remain attached to a post
The image(s) could be saved in a temporary place for checking. All the images for a post would probably be saved and checked before being moved to the final place which could be as a database blob. So it might be the total size of all the attachments to a post that is significant.
05-11-2015 2:11 PM
05-11-2015 2:15 PM
It may be totally unrelated and not implying anything but I can't help notice that the issue of lack of space has only appeared since 'spoon whittler' made this post:
http://community.plus.net/forum/index.php/topic,133711.0.html
Reply 23 : I think if it is an issue over contention this issue would have appeared before, and on a system designed to support thousands of concurrent users can't support two of them uploading at the same time then an upgrade or replacement is required.
05-11-2015 2:20 PM
As for that post we could ask a mod to delete it altogether and see if that solves the problem
Edit: I've reported the post for deletion
05-11-2015 2:34 PM
05-11-2015 2:40 PM
05-11-2015 2:42 PM
05-11-2015 2:44 PM
Quote But this is a serious enough issue, that clearly Plusnet are at a loss to solve at present
I'm not sure why you believe that? The problem isn't a high priority in the grand scale of things, there is a workaround available (uploading to image hosting sites and linking) and to be quite frank it's not been looked at yet since I reported it.
- Feedback
