Upload folder full when trying to attach images to posts
Re: Upload folder full when trying to attach images to posts
It may not be that the upload dir is full but the actual device on which the upload dir is on is full.
If I were you I'd check my system logs and see what information they contain, but I assume this has been done.
I would have thought that the upload dir should in fact a temp store so that anything uploaded was in effect quarantined, and after passing inspection would be moved to a permanent place and the uploaded file removed from disk. But hey what do I know!
Anotherone
Champion
Fixes: 21
Silly question, how can the Uploaded file be removed from disk if it's to remain attached to a post - unless I've misunderstood what you were trying to say. As far as the actual device being full is concerned, interesting. I think there are 2 servers (certainly 2 IP addresses) and there will be other stuff on these servers as well (I don't think they are dedicated to the forum - might be wrong) so some other carp on them may have filled one of them - anything's possible!
Sensible answer. I say in my post that the uploaded file is removed as it has been moved (copied) to its permanent home having been checked for viri et al. This then allows the original file to be deleted.
Anotherone
Champion
Fixes: 21
Right, see what you are saying, don't know how clever or not, this particular set up is, but with the limited file types it might not need to be too clever.
drunkenmonkey
Just got the issue here with a 35kb and 65kb file Sad
w23
Fixes: 4
Just failed with a 28k '.jpg' file
LOL, just got:
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
while trying to post that.
Call me 'w23'
Well this may well be redundant but...
If you can load a file of 11kB but not one of 55kB then yes you're maybe short of disk space. However, if you then do another upload of a 45kB file then this should fail, and repeating the process several times with an 11kB should result in no uploads being allowed.
But this does not appear to be happening, so someone needs to look at the device (/var/tmp/, /var/spool) used when reading the HTTP upload stream, I assume there is some configuration option somewhere to set this. It may well be that the temp stream device that is running out of space so not related to the physical size of the upload dir, which explains why all the setting still look sane.
jelv
Fixes: 10
Quote from: Anotherone
The image(s) could be saved in a temporary place for checking. All the images for a post would probably be saved and checked before being moved to the final place which could be as a database blob. So it might be the total size of all the attachments to a post that is significant.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jelv
Fixes: 10
Another thought: if it's a temporary work area and two people are trying to attach images at the same time...
Reply 22 : If that were the case then you wouldn't get an error while uploading a single file.
It may be totally unrelated and not implying anything but I can't help notice that the issue of lack of space has only appeared since 'spoon whittler' made this post:
http://community.plus.net/forum/index.php/topic,133711.0.html
Reply 23 : I think if it is an issue over contention this issue would have appeared before, and on a system designed to support thousands of concurrent users can't support two of them uploading at the same time then an upgrade or replacement is required.
Anotherone
Champion
Fixes: 21
Well, I see what spoon whittler is getting at, but it's not been a problem before that I can ever recall. There is a limit set for total size of attachments per post (or can be) but it can't be that when trying to upload just one file of 55K or whatever.
As for that post we could ask a mod to delete it altogether and see if that solves the problem Grin  He could always post it again if it doesn't make any difference Crazy
Edit: I've reported the post for deletion  Tongue
Fixes: 1,495
nope, we removed the deletion of posts after some whoopsies.
Chris
Legend
Fixes: 169
FYI, I've linked to this thread on the internal problem so the people who will look at it know the suggestions and what's been tried.
Anotherone
Champion
Fixes: 21
Sorry dvorak, what exactly do you mean by that? You won't delete it, because it'll break your new rules? Or you can't because that ability has been removed. If the latter, then a relevant member of Plusnet staff will have the admin privileges to do it. If you mean the former, then this is a time to break the rules. I've been wondering if it's possible that the technique has been going around in an endless loop until it's filled up the Upload folder - I don't know. But this is a serious enough issue, that clearly Plusnet are at a loss to solve at present. If it did turn out to be the cause then SMF need alerting to see if later versions are vulnerable to the same problem and the technique should be binned asap.
Chris
Legend
Fixes: 169
I'm not sure why you believe that? The problem isn't a high priority in the grand scale of things, there is a workaround available (uploading to image hosting sites and linking) and to be quite frank it's not been looked at yet since I reported it.
