Copy/paste image from Excel to this forum
kbturner
I've got a graph ('chart' in Excel terminology) that I wish to insert to a message to this forum.
I don't want to upload it to some other site first.
I don't even want to save it as a file.
I've simply copied it to the clipboard, but I don't seem to be able to paste it into the forum message.
I've seen other messages that seem to have achieved what I'm after.
How's it done?  Am I missing something here?
11 REPLIES 11
Re: Copy/paste image from Excel to this forum
Save the image to your PC then click the 'Additional Options and Attachments' link where you compose your (this) message, hit the browse button, select the image and Post the message.
Fixes: 1,494
you can't do what you want, you'll need to save it as a file.
kbturner
Quote from: Mook
...  click the 'Additional Options and Attachments' link where you compose your (this) message, hit the browse button, select the image and Post the message.
OK, I've done that, but it doesn't appear when I do a preview.
I don't want to post it without seeing what it looks like in the preview.
Oldjim
Resting Legend
Fixes: 63
You don't see it in preview
However after posting you can select edit (not quick edit) and additional options again and you can remove it
kbturner
Thanks for that, Oldjim.
I take it when you say "select edit", you mean hit the "Modify" button?
Oldjim
Resting Legend
Fixes: 63
yes I do  Embarrassed
kbturner
Right, I've done as you suggested, Oldjim,  and the results are here:http://community.plus.net/forum/index.php/topic,133718.0.html.
I would quite like to blow up the picture a bit, and move it from the message footer into the middle of the text.  Is that possible?
Oldjim
Resting Legend
Fixes: 63
Only by posting it on a website somewhere and using a link
However clicking on the image makes it larger and easily readable
kbturner
Aaah.  Sad
All a bit clunky isn't it?
jelv
Fixes: 10
Just stumbled across this old post and there's a way to do it (if you don't mind having the thumbnail as an attachment as well as the full image in the post).
1. Post the image as an attachment
2. Then view the post and click on the attachment - grab the URL of the attached image which will be something like http://community.plus.net/forum/index.php?action=dlattach;topic=133718.0;attach=53342;image
3. Edit the post and insert the image.
From the OP's posts he'd have got this:
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Anotherone
Champion
Fixes: 21
Thanks for that tip, hadn't ever thought of that for an original post of my own, have done similar iirc with an image grabbed from another post. Wink
