Slightly annoying design faults?
- Feedback
- Community Site Feedback
- Slightly annoying design faults?
10-05-2016 11:51 AM
Two that really irritate:
1. a pinned thread appears twice in the list if a new message is added to it
2. a message selected as a "fix" appears twice in a thread and the link to the message points to the (redundant) added/displayed copy
Missing preference options:
1. not option to turn off avatars
2. no option to suppress display of entries in the column containing "New fixes" etc
Phil
Re: Slightly annoying design faults?
10-05-2016 12:05 PM
I've given up reporting all the problems I'm seeing with this forum.
I'm clearly wasting my time providing debug info, as nothing is getting fixed.
10-05-2016 3:37 PM
I am always taking in feedback and making notes so don't think that your efforts are in vain!
Unfortunately the OP is describing things that cannot be changed as thats the standard way that this system works.
During testing we flagged up the pinned thread duplication but this is just how the system works. I might be able to come up with some Javascript and try to physically hide/remove the duplicated thread so I have added this to my enhancement list.
We asked why the 'fix' was displayed twice but it actually makes sense this way - users who have come to the thread to get the 'fix' will see the solution straight away instead of having to scroll through pages of replies. The reason its repeated is so you can still go through the normal flow of replies.
There is no option to turn off avatars but I can certainly put the idea forward to Lithium to implement something in a future release.
I am unsure what you mean with the supressing of entries on the 'new fixes' panel. There is currently no options to change the amount of items displayed on the homepage. We are looking at changing the homepage in the future to utilise the options in the settings so you can change the amount of subscription entries that are displayed but that will come at a later date when we have ironed out some of the more important issues raised. The settings I speak of only work for some panels and we have a few more than what is available in the settings.
Rest assured, I am always reading feedback and I for one welcome it so if there is something that is bugging you or if you think something could be improved around here please create a topic and we can discuss it and possibly get some ideas going and get things changed.
Just a heads up, I am just a Front End developer and can't change how the system works (that would be down to Lithium) but I can create some (limited) customisations and change things at a visual level so I am open to ideas.
10-05-2016 7:40 PM
In that case, when should we expect to start seeing problems reported more than a month ago being fixed ?
10-05-2016 11:01 PM
We asked why the 'fix' was displayed twice but it actually makes sense this way - users who have come to the thread to get the 'fix' will see the solution straight away instead of having to scroll through pages of replies. The reason its repeated is so you can still go through the normal flow of replies..
We will have to agree to disagree A link to the copy of the fix is added to the post when a fix is selected. This should point to the actual post which means no manual scrolling would be needed to go directly to it and also puts it context of the thread.
Phil
11-05-2016 8:49 AM
I have a bunch of updates ready to go live that have gone through code review and QA testing. I am just waiting for the go ahead to put them live as I need to have these things signed off by CM. @LouisaMartin, do you know when we can expect to push the changes from staging to live?
As for what is being updated, I am going to be posting those details before the fact here.
11-05-2016 9:13 AM
Well that will be "interesting" as I haven't seen a complete list anywhere else.
11-05-2016 9:20 AM
Please keep reporting the problems, unless we continue to do so, things will go from bad to worse.
However, I do think you are wasting your time providing debug info as I'm seriously beginning to doubt whether Lithium are competent enough to understand it or indeed whether they actually understand some of the basic problems we've uncovered
11-05-2016 9:20 AM
@Anotherone, the complete list is not public and is in our internal system.
A list of changes being rolled out are posted on the staging site (as you already know).
11-05-2016 9:21 AM
I will reply over there Jack, before I lose my cool.
11-05-2016 9:27 AM
I hope I haven't upset you in some way @Anotherone...
11-05-2016 9:28 AM
Not you personally Jack.
11-05-2016 9:30 AM
It is very difficult to remain enthusiastic about reporting errors when staff give no indication of doing anything about month old fault reports, when every damn page takes 9 to 20 seconds to load, posts vanish, the editor fails, and general navigation is such a struggle.
11-05-2016 9:35 AM
With that sort of issue, I can fully understand why you are struggling with general navigation. As I am not experiencing that issue, I'm can't make any obvious suggestion at this time.
11-05-2016 9:53 AM
@PeeGee wrote:
@jaread83 wrote:
We asked why the 'fix' was displayed twice but it actually makes sense this way - users who have come to the thread to get the 'fix' will see the solution straight away instead of having to scroll through pages of replies. The reason its repeated is so you can still go through the normal flow of replies..We will have to agree to disagree
Phil
Phil that is precisely what I said in testing. Even knowing that's the case, I find it difficult to scroll past the duplicate "fix" response at the top of the thread, and as most threads are not simple non-tech issues, it makes reading the thread more disjointed.
Further more, when you look at a thread that only has the OP and a single simple one answer fix, it not only looks stupid, it looks totally unprofessional - another comment that I made.
@jaread83 I disagree that it makes sense when there is a link, you know my opinion about this and I've just repeated it.
I thought that as a result of this Lithium were requested to provide an Option to turn it off, along with an option to turn off the duplicate fix, are you saying that is not the case? Perhaps @LouisaMartin can answer that?
