Ranking system going crazy?
- Feedback
- Community Site Feedback
- Ranking system going crazy?
Re: Ranking system going crazy?
26-04-2017 12:15 PM
@Browni - looking at your stats, you are pretty much bang on the rank for 'all star'. This rank bouncing thing is really strange... there is a large buffer between each one and I suspect the system goes nuts when one of your stats is EXACTLY the amount needed to go to the next one. Minivanman has also PM'd me about it and I have asked Lithium to look at our ranking system as I suspect this to be a bug.
26-04-2017 12:34 PM
05-05-2017 5:44 PM
it has just happened to me ? @jaread83
08-05-2017 5:11 PM
weird just happened again ? @jaread83
08-05-2017 5:15 PM
@rongtw The second one just looks like a normal rank up from Champion to Seasoned Champion
08-05-2017 7:09 PM
@HarryB yes but the previous one is exactly the same ? and 2 rank ups in 20 seconds ?![]()
09-05-2017 6:25 AM
wow !!!!! its done it again
09-05-2017 8:59 AM
I've seen it several times as I've 'ranked up'. The algorithm that decides your ranking is a bit flaky ( 'ill conditioned' in maths terminology) and there is a gap where it can evaluate you as 'In' or 'Out' depending on the current value of the parameters.
It needs to be made more robust and only confirm the new rank once it is stable. First reported back in the early days of this new Forum, so it should come to the top of the Lithium mañana pile 'real soon now' . ![]()
09-05-2017 10:22 AM
It must use "The hokey cokey" algorithm
In out,
in out.
shake it all about.
09-05-2017 10:41 AM
Well whatever algorithm it does use it needs some attention that's for sure, as something's not right.
09-05-2017 4:03 PM
I know !!! its Ms Abbots Algorithm ![]()
09-05-2017 4:17 PM
Gremlins are about i just ranked up twice again ![]()
09-05-2017 5:09 PM
09-05-2017 6:06 PM
Well there must be an issue with the underlying eventing system, surely this isn't the intended mode of operation?
09-05-2017 6:08 PM
I've started seeing the issue, having just been ranked up twice
