Ranking system going crazy?
jaread83
Fixes: 81
Re: Ranking system going crazy?
@Browni - looking at your stats, you are pretty much bang on the rank for 'all star'. This rank bouncing thing is really strange... there is a large buffer between each one and I suspect the system goes nuts when one of your stats is EXACTLY the amount needed to go to the next one. Minivanman has also PM'd me about it and I have asked Lithium to look at our ranking system as I suspect this to be a bug.
Browni
Aspiring Hero
Fixes: 61
@jaread83 here's a larger screenshot showing both instances today
rongtw
Fixes: 12
rongtw
Fixes: 12
weird just happened again ?   @jaread83
HarryB
Fixes: 256
@rongtw The second one just looks like a normal rank up from Champion to Seasoned Champion
 Harry Beesley
rongtw
Fixes: 12
@HarryB yes but the previous one is exactly the same ?  and 2 rank ups in 20 seconds ?Huh
rongtw
Fixes: 12
MauriceC
Resting Legend
Fixes: 17
I've seen it several times as I've 'ranked up'.   The algorithm that decides your ranking is a bit flaky ( 'ill conditioned' in maths terminology) and there is a gap where it can evaluate you as 'In' or 'Out' depending on the current value of the parameters.
It needs to be made more robust and only confirm the new rank once it is stable.  First reported back in the early days of this new Forum, so it should come to the top of the Lithium mañana pile 'real soon now' .  Grin
SpendLessTime
Fixes: 86
It must use "The hokey cokey" algorithm
In out,
in out.
shake it all about.
Well whatever algorithm it does use it needs some attention that's for sure, as something's not right.
rongtw
Fixes: 12
I know !!! its Ms Abbots Algorithm Cheesy
rongtw
Fixes: 12
Gremlins are about i just ranked up twice again Shocked
HarryB
Fixes: 256
@Anonymous - The ranking formula seems fine in the settings. Hopefully @jaread83 gets some more insight from Lithium on what's causing this.
 Harry Beesley
Well there must be an issue with the underlying eventing system, surely this isn't the intended mode of operation?
DaveyH
Champion
Fixes: 12
I've started seeing the issue, having just been ranked up twice
