Quick edit not working under FF?
Colin
Re: Quick edit not working under FF?
That reminds me, I think he passed me the task with the fix earlier in the week.
[me=Colin]goes to check[/me]
Colin
I did have a task for it, which I've now followed through and started the procedure for getting it rolled out. Won't be until Monday.
MikeWhitehead
Nice one, can't wait to see it (and see it working hopefully :P)
Colin
This should now be fixed...
MikeWhitehead
It WASN'T working for me under Firefox 2.0.0.7, but it is now (I just used it to edit this post) Tongue
Colin
Tried force refreshing the page? I've got it working in IE 7.0.5730.11 and Firefox 2.0.0.7...
Testing this in Opera...
MikeWhitehead
Yep I tried that a couple times and it still didn't work. It works now though! Nice work Smiley
Kelly
Fixes: 9
Could be a cached stylesheet or something.
Sorry for breaking it in the first place!  (On behalf of Tam Wink )
Kelly Dorset
Ex-Plusnet Jobsbody
Oldjim
Resting Legend
Fixes: 63
Not sure - second try with quick edit (and it worked)
MikeWhitehead
Seems cleaned up to me. Get a few others to test in Opera/Safari/etc to make sure it doesn't crack up?
7th_star
Works in Opera. Smiley
"Quick edit" to add smiley.
Simon_M
Yep - sorted in FF. Just 'Quick Edit'ed my earlier post to prove it works retrospectively.
Thanks for getting it sorted.
pcoventry76
it has always worked for me on FF - i've never needed to take any action
MikeWhitehead
The problem was that the Quick Edit would function correctly in the fact that it would take the post, reparse it and wrap it in a textarea, but when you tried to save the changes, the save wouldn't register and would get stuck there.
