Priority - Forum bugs have appeared
Anotherone
Champion
Fixes: 21
Re: Priority - Forum bugs have appeared
New, well not new actually, only recently sunk-into-skull bug Embarrassed
Font in even recent "Quoted posts" is not the new darker colour @mtrinder I'll drop you a PM later.
wisty
Fixes: 8
@Anotherone wrote:
The Fly-out menu from your Username/Avatar on the top right - if you are quick enough Huh then you can select the option you want,
or ii) Right click and open your profile in a new tab. Then try the fly-out again, and this will allow you to try as many times as it takes to try and select the option you want without messing up your original tab.
If anyone has any better work-arounds, please post them.
Don't know if it helps the debugging (or as a workaround), but with Edge if I right click the tab and duplicate it, the duplicate seems to behave properly. No idea why!!!
Edit an hour later - at least it works for a while, then starts to misbehave. Creating another duplicate fixes it until....
Anotherone
Champion
Fixes: 21
Well, at time of making this post, all bugs still present.
rongtw
Fixes: 12
i notice we have this post  pinned at top of page , but still shows as a normal post below Crazy3
Anotherone
Champion
Fixes: 21
That's the crazy way this Lithium powered stuff works. We have requested that pinned threads don't display a "duplicate" but that has not as yet been forthcoming. Apparently according to quotes, this as an option has been requested from Lithium as early as 2009 IIRC, so your guess is as good as mine as to how long it will take. We will continue pressing.
Anotherone
Champion
Fixes: 21
BEWARE another bug - please note @mtrinder @HarryB @Chris
I just went to Preview a PM, and on three consecutive occasions, the whole contents, title and to whom, just vanished. So do a copy all of what you've written before doing Preview, just in case, and until we are certain that all these intermittent bugs have been fixed.
It worked OK on the 4th try, but if you find it persists, just don't bother with Preview.
Edit: I just got the Leave Page warning when moving between Settings tabs Crazy3
John_Essex
@John_Essex wrote:
Yet another issue Sad
If I try and review a post I get a pop up box asking if I want to leave this page then the preview behind it.
Clicking no stay on this page clears the pop up but there is no option to go back to the original composition.
It's going from bad to worse !!
 Yep already found that one the other day so glad it's not just me seeing that one. Roll_eyes
Anotherone
Champion
Fixes: 21
I take it you've read message #40 John?
John_Essex
I have but that doesn't seem to mention the preview bug.
Anotherone
Champion
Fixes: 21
No:3 on the list John Wink
HPsauce
Seasoned Pro
Fixes: 4
As @Anotherone said (I haven't a clue how to quote a post, it's far from obvious!):
  • If you get an Authentication error when trying to mark a Post/Topic Read or New, just go back one in your Browser and try again. The same applies if trying to Bookmark and probably anything else.
    BUT if it involves a post, remember 4 above. Repeat until it works - or give up until later Roll eyes
........ If anyone has any better work-arounds, please post them.
Well, as I've mentioned a couple of times, I do have a work-around, but it's not pretty:
This works for me RELIABLY with IE11 on W10x64:
When you get an authentication error, repeat the action in another (new) tab or window.
I typically do this by right-clicking on the (failed) action and choose "open in new window(or tab)"
Then do it in that new window/tab and it invariable works.
I'd like to know if this works for anyone else, it may help with diagnosis/fix.
Anotherone
Champion
Fixes: 21
wisty posted a similar work around , so it sounds good.
Re: quotes - If you click reply on the relevant post HP, you should then see the quote button. You can edit bits of the quote before you post if you want. You don't get an automatic link (something we are pressing for) you have to create it manually.  You can get the actually link from the message number.
HPsauce
Seasoned Pro
Fixes: 4
 Thanks, found that a short while ago. Cool
 I'm learning (slowly), but wondering why I'm bothering as it's so different to any other forum I inhabit. Cry
John_Essex
Looks like I need to either get some new glasses or stop trying to speed read. Embarrassed
Anotherone
Champion
Fixes: 21
We've all done it John Embarrassed
@HPsauce
It is, but once you get to know your way around it seems better than you thought - minus the bugs of course Ticked_off  And even I have just learnt a new trick which I'll post about when I've compiled it.
