Post immediately rejected
Obs
Tried to post a reply on a topic and I'm told my post is awaiting approval.  Click on this link and it says I have no posts waiting approval and that the post is in the Rejected list with no explanation why.  And without that initial link how on earth would you get to that page - it's not at all obvious.
11 REPLIES 11
Obs
Re: Post immediately rejected
Just reposted it as a reply to original topic rather than a reply to to a reply... and it posted..
Obs
Scratch that. All though it said it was successful and appeared in the thread.  Going back to it, it has disappeared!
Strat
Fixes: 565
The post was caught by the spam filter.
I have released it to the thread.
PS As you made 2 attempts at making this post I have removed the duplicate.
Obs
Thanks,  the second attempt appears did not trigger the spam filter.  Whether this was because it was a reply to the original post, rather than a reply to a reply, or because I used the edited version of the first post where I had spaced out domain names so they did not automatically get converted to links I cannot say.
Strat
Fixes: 565
Obs wrote: the second attempt appears did not trigger the spam filter
It did actually. I released both from the spam filter, one after the other and removed the second from the thread.
jaread83
Fixes: 81
The spam filter is a bit sensitive at the moment but its a learning system so if your posts have been approved it should know not to flag your posts from now on. Please let us know if any of your posts get flagged again and it will get sorted out for you.
Chris_P
After an apparent lapse of six years, this happening to me today. When I try to refer to the moderator, using the Post option menus, I am rejected as in screenshot. Not holding my breath for this post to be accepted. And yes, I am sure I want to reply.
Chris_P
Moderator has now released post i was tryng to make from "automatic spam filter"..(https://community.plus.net/t5/My-Router/HubTwo-disconnects-Ehernet-LAN/m-p/1899917#M34150)
Fixes: 480
I have now removed its duplicate.
Huggybear
I just had this happen to me for my first lengthy post describing my problem. Can someone please check the spam log?
Fixes: 480
@Huggybear  Post released from spam filter.
