Numbered lists display incorrectly
- Feedback
- Community Site Feedback
- Numbered lists display incorrectly
08-09-2017 3:52 PM
If there are more than 9 entries in the list they display 1 - 9 and then 0,1,2......
It displays correctly in the editor, but only shows up when posted.
If it helps @jaread83 I can PM you a link to an example.
Re: Numbered lists display incorrectly
08-09-2017 4:53 PM
Looks fine to me. The <ol> tag css could probably do with a little more padding as numbers after 20 are slightly cut off.
09-09-2017 3:11 PM
Confirmed @jaread83. On the post link I PM'ed you, the numbering cut off is much greater, but adjusting the <ol> Left-padding from 20 to 25 sorts it. ![]()
11-09-2017 9:07 AM
25-09-2017 2:01 PM
