Change in behaviour when clicking on attachments
- Feedback
- Community Site Feedback
- Change in behaviour when clicking on attachments
03-09-2017 12:37 PM
Since FF was updated to 55.0.3 I have noticed that instead of attachments (jpg, png, etc) opening in the next tab I started to get a pop-up asking where I wanted to save it or which app to open it with:
Initially I thought there may have been a setting changed particularly in TabMixPlus but nothing appears obvious.
I thought if I select Firefox then things may continue as they did but the image was opened in a new tab at the end rather than next to the current one. I still get this pop-up every time.
I don't see this happening in other forums hence posting here rather than Tech Help.
Forum Moderator and Customer
Re: Change in behaviour when clicking on attachments
03-09-2017 12:44 PM
@Mav - When viewing your thread and I click on your image it appears in a popup window (I think it's called a lightbox?). Can you provide an example link where this is happening please.
03-09-2017 12:47 PM - edited 03-09-2017 12:49 PM
I've re-added the image above using the Browse button rather than Images button (if you see what I mean) so it shows as an attachment at the bottom of the post rather than within the post.
Attachments embedded within the post open as expected (lightbox) but those added using the Browse button no longer open in the next tab as they used to (but seemingly only for this forum).
03-09-2017 1:11 PM - edited 03-09-2017 1:17 PM
I'm seeing the same problem using Pale Moon x64.
eta: Same in Microsoft Edge so lithium have broke things again ![]()
03-09-2017 1:21 PM
@Mav, yes I see now, I too get the same behaviour on Mac with FF v55.0.3
03-09-2017 1:30 PM - edited 03-09-2017 1:30 PM
Glad it's not just me, then![]()
Just wish I could find a way to revert to how it was but no success as yet.
04-09-2017 2:50 PM
13-09-2017 6:17 PM
I'm beginning to find it a little annoying now as the number of attachments needed to check can be numerous at times.
As I haven't seen this in any other forums or sites (yet) is it something Lithium has implemented and can it be returned to how it was?
13-09-2017 9:24 PM
13-09-2017 9:38 PM
13-09-2017 9:43 PM
Sorry, Mav - I wasn't having a go at Jack, I agree he has done a fantastic job with the forums - it was a tongue-in-cheek type comment that didn't translate well. ![]()
15-09-2017 4:53 PM
15-09-2017 4:56 PM
25-09-2017 9:26 AM - edited 25-09-2017 9:27 AM
I have heard back from Lithium support.
Okay, so this change was intentional BUT there is a new setting in the admin panel to change how this behaves. I have switched this setting on for now to see what it does. So PDFs, text files, word docs and similar will all open with an online viewer. Unfortunately, for images this does not apply and they will still need to be downloaded to be viewed in a photo viewer on your computer.
For images, I would encourage everyone to use the dedicated image functionality when posting images so that they appear in the post. For mobile and tablet users - you will still need to use the attachment functions for adding images to posts.
I will try and find a work around for this but it could be a bit more complicated than simply flipping a switch in the code.
- Feedback
