Mentions in quotes
- Feedback
- Community Site Feedback
- Mentions in quotes
Mentions in quotes
14-02-2018 3:10 PM
Is it possible for mentions inside quotes not to result in a mention email?
I've just received an email for a post where I quoted a post by someone else which mentioned me. This is the beginning of the email:
Hi jelv, jelv (Community Veteran) mentioned you in a post! Take a look at what they said and join in the conversation here:
Re: broadband usage gone sky high
@JonoH wrote:
@jelv wrote:
In the past Plusnet have refunded excess usage charges where this has happened and the user has complained.
Somewhat confused me at first as I wondered why I was mentioning myself. It does not appear in the notification feed so why the email?
Re: Mentions in quotes
16-02-2018 1:06 PM
@jaread83 Is this something we can do?
16-02-2018 3:03 PM
Moderators: this is a deliberate full quote to generate the circumstances I've raised.
jaread83: If you get emails for mentions you will find this post generates one but I think you will find it is not in your notification feed.
20-02-2018 9:50 AM
20-02-2018 4:45 PM
Can you confirm you saw the same as me - you had an email but it didn't appear in the notification feed?
21-02-2018 9:22 AM
21-02-2018 9:35 AM
I just received a notification for for this post - I don't have emails setup - https://community.plus.net/t5/Plusnet-Feedback/New-Service-Status-System/m-p/1516440#M80652
21-02-2018 9:43 AM
21-02-2018 9:50 AM
if that was me - no I didn't
But why should an @ mention in a quote count as it isn't really a mention
21-02-2018 10:00 AM
Now, in the old system a quote would have your username in plain text 'Oldjim wrote:' so if you were to ask me to delete your account - any quoted text (in the old system) would still say 'Oldjim wrote:'. This is a problem as it means that we need to find all quoted text with your username and remove it manually.
The new system is using the @ mention system as a way to automatically do this from now on. So if I was to delete your account, any quoted text would read as 'Anonymous wrote:' as the @ mention system does not recognise the userID in the lookup so then it becomes an anonymous user which should keep the GDPR people happy that we can delete all user data.
I personally think that Lithium need to seperate the @ mention system into two and have the normal one function as it was and then another one that simply looks up a username without linking it or notifying a user that they were mentioned.
But as I said.. I don't know how their code is set up and the above is simply my best guess as to why this system is being used (for GDPR).
21-02-2018 12:48 PM - edited 21-02-2018 12:52 PM
Not sure if you have the two types of mention right. Surely it should be:
- A mention that is linked and generates email and notification feeds.
- A mention that is linked only and generates no email or notification
Both types have to be linked to meet GDPR.
When you quote a post it should convert all type 1 mentions in the quoted post to type 2, then add a header to the quoted post with a type 1 mention.
If someone types a mention that will be a type 1, unless it it is inside a quote when it should be type 2.
If someone selects a block of text and then clicks the blockquote button, any mentions within the selected text should be converted to type 2.
To do this just requires an extra parameter in <li-user login="jaread83" uid="4"> e.g. <li-user login="jaread83" uid="4" nonotify="Y"> for the type 2 mentions.
22-02-2018 11:57 AM
16-04-2018 9:27 AM
