Error when posting a reply
MauriceC
Resting Legend
Fixes: 17
Got this error when posting a reply about 09:46 this morning.  Win7 FF 58.0.2
Posting a reply with ( possibly? ) an error in the link I added.plusnet error.jpg
9 REPLIES 9
Fixes: 246
Re: Error when posting a reply
Seeing similar to this (authentication errors) a lot - especially when I start typing a reply, get distracted and return to it sometime later.  I suspect that the website session expiry time is far too short.
Fixes: 1,495
could also occur if we're moving posts around, I think.
MauriceC
Resting Legend
Fixes: 17
@dvorak  Unlikely,  it was a new 'escalated' Topic I was adding details to.
@Townman  It was a new Topic and even with editing would be less than 5 minutes
jaread83
Fixes: 81
Not sure what could have happened here. You don't have any restrictions applied to your usergroup within that area and should be able to post quite freely. I will send a support ticket off to Lithium to find out some answers.
MauriceC
Resting Legend
Fixes: 17
It is odd @jaread83 Roll_eyes     I've successfully posted other topics since this occurred.  Reported as an example, not an annoyance.
jaread83
Fixes: 81
No worries. Thanks for providing a timestamp too, that will help Lithium support take a look at what happened on the logs.
jaread83
Fixes: 81
Hi @MauriceC, I have a few questions that should aid Lithium support.
What browser were you using when you encountered the error?
How often does this happen to you?
If it happens very often, do you have any browser addons that you could try disabling to see if that is causing an issue?
Cheers
MauriceC
Resting Legend
Fixes: 17
As in the OP  Win7 and FF 58.0.2 64 bit
This was the only time I've seen this error
jaread83
Fixes: 81
Hi all, Lithium have informed me that a fix has been rolled out for this. I will keep my eye on it.
