Initial Queries
artmo1
Initial Queries
Just had a look at the new site. Why has my username got a number 1 on the end?
I've looked in profile and can't see how to add an aviator and sig. Where is this done?
11 REPLIES 11
Anotherone
Champion
Fixes: 21
Re: Initial Queries
Everything you need should be on the "My Settings" on the fly-out menu by clicking your forum name/avatar but https://community.plus.net/t5/user/myprofilepage/tab/personal-profile will take you to where you can change your ID. Make sure your email address is right!
Oldjim
Resting Legend
Fixes: 63
Re: Initial Queries
that is because you registered a new account instead of resurrecting your old one assuming that you are actually artmo
Chris
Legend
Fixes: 169
Re: Initial Queries
You need to log out of this account and reset the password on your 'artmo' account. That's where your post count is too.
It seems that the artmo1 account is from 2008 and actually has 1 previous post too!
Mustrum
Fixes: 81
Re: Initial Queries
Just checking to see if I did it right!
artmo1
Re: Initial Queries
I am still having problems. I have logged out of the incorrect, artmo1, account but each time I try to enter the correct account, artmo I am taken back to artmo1.
David_W
Re: Initial Queries
Is the email for Artmo different from Artmo1?  Though if they are the same, that'll be fun to try and fix.
Chris
Legend
Fixes: 169
Re: Initial Queries
I'll send you a PM shortly with how to fix it.
Anotherone
Champion
Fixes: 21
Re: Initial Queries
You need a bit of help from @Chris or @bobpullen by the sound of it.
Edit: Chris types faster Embarrassed
Chris
Legend
Fixes: 169
Re: Initial Queries
Bingo Wink
artmo
Aspiring Champion
Re: Initial Queries
Thanks Chris problem solvedSmiley
Chris
Legend
Fixes: 169
Re: Initial Queries
Excellent Smiley
