Initial Queries
- Feedback
- Community Site Feedback
- Re: Initial Queries
Initial Queries
07-04-2016 2:49 PM
Just had a look at the new site. Why has my username got a number 1 on the end?
I've looked in profile and can't see how to add an aviator and sig. Where is this done?
Re: Initial Queries
07-04-2016 2:53 PM - edited 07-04-2016 2:53 PM
Everything you need should be on the "My Settings" on the fly-out menu by clicking your forum name/avatar but https://community.plus.net/t5/user/myprofilepage/tab/personal-profile will take you to where you can change your ID. Make sure your email address is right!
Re: Initial Queries
07-04-2016 2:57 PM - edited 07-04-2016 2:58 PM
that is because you registered a new account instead of resurrecting your old one assuming that you are actually artmo
Re: Initial Queries
07-04-2016 3:06 PM - edited 07-04-2016 3:10 PM
You need to log out of this account and reset the password on your 'artmo' account. That's where your post count is too.
It seems that the artmo1 account is from 2008 and actually has 1 previous post too!
Re: Initial Queries
07-04-2016 3:10 PM
Just checking to see if I did it right!
Re: Initial Queries
07-04-2016 4:30 PM
I am still having problems. I have logged out of the incorrect, artmo1, account but each time I try to enter the correct account, artmo I am taken back to artmo1.
Re: Initial Queries
07-04-2016 4:32 PM
Is the email for Artmo different from Artmo1? Though if they are the same, that'll be fun to try and fix.
Re: Initial Queries
07-04-2016 4:32 PM
I'll send you a PM shortly with how to fix it.
Re: Initial Queries
07-04-2016 4:33 PM - edited 07-04-2016 4:33 PM
You need a bit of help from @Chris or @bobpullen by the sound of it.
Edit: Chris types faster ![]()
Re: Initial Queries
07-04-2016 4:36 PM
Bingo ![]()
Re: Initial Queries
07-04-2016 4:51 PM
Thanks Chris problem solved![]()
Re: Initial Queries
07-04-2016 4:52 PM
Excellent ![]()
