Incorrect links on sub-forum icons
jelv
Fixes: 10
I've realised that I should have reported this as a bug rather than as a suggestion which is why it has been ignored. As I can't report my own post for being in the wrong forum I'll remake it here - perhaps a moderator could remove the post from the Suggestions (Community Site and Forums) please.
On the image attached there are the following links.
under Your Feedback links to http://community.plus.net/forum/index.php?action=unread;board=49.0
under Product / Service Announcements links to http://community.plus.net/forum/index.php?action=unread;board=2.0
beside Rants and Raves links to http://community.plus.net/forum/index.php/board,47.0.html
beside Testamonials links to http://community.plus.net/forum/index.php/board,46.0.html
The last link should be to http://community.plus.net/forum/index.php?action=unread;board=46.0 (if you click this link you will find it does work as expected)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
8 REPLIES 8
Oldjim
Resting Legend
Fixes: 63
Re: Incorrect links on sub-forum icons
Original post removed as requested.
For the future a PM to the mods makes itt much easier
jelv
Fixes: 10
Is anyone from Plusnet looking at this forum? It's a month since I posted this topic.
MauriceC
Resting Legend
Fixes: 17
Hi jelv,
I've added this problem into PUGIT as PUGIT 436.
It may not expedite the resolution, but it should make it easier to search for Cheesy
jelv
Fixes: 10
Is anybody from Plusnet going to respond to this topic or the PUGIT item?
Chris
Legend
Fixes: 169
So from what I can gather, the problem is that the image next to the subforum name doesn't link to unread posts whereas the image next to the main forum does?
Having a quick look around, it looks like this is the normal behaviour of SMF there doesn't seem to be an option to change where it links to.
jelv
Fixes: 10
Something has been done to this forum to make it display the standard or New small sub-forum icon - having code to display the appropriate icon, surely it's behaviour should then be consistent with the large standard/new icons.
Most other forums don't have the small icons so the issue doesn't arise.
Colin
I'll add it to a couple of other things I need to do, hopefully possibly next week.
Colin
Not this week, but should be next week
