Incorrect links on sub-forum icons
- Feedback
- Community Site Feedback
- Incorrect links on sub-forum icons
10-02-2009 12:49 PM
On the image attached there are the following links.
under Your Feedback links to http://community.plus.net/forum/index.php?action=unread;board=49.0
under Product / Service Announcements links to http://community.plus.net/forum/index.php?action=unread;board=2.0
beside Rants and Raves links to http://community.plus.net/forum/index.php/board,47.0.html
beside Testamonials links to http://community.plus.net/forum/index.php/board,46.0.htmlThe last link should be to http://community.plus.net/forum/index.php?action=unread;board=46.0 (if you click this link you will find it does work as expected)
Re: Incorrect links on sub-forum icons
10-02-2009 12:54 PM
For the future a PM to the mods makes itt much easier
18-03-2009 3:45 PM
18-03-2009 4:32 PM
I've added this problem into PUGIT as PUGIT 436.
It may not expedite the resolution, but it should make it easier to search for
24-04-2009 3:38 PM
24-04-2009 3:44 PM
Having a quick look around, it looks like this is the normal behaviour of SMF there doesn't seem to be an option to change where it links to.
24-04-2009 4:03 PM
Most other forums don't have the small icons so the issue doesn't arise.
24-04-2009 10:55 PM
29-04-2009 3:13 PM
