I'm not here
- Feedback
- Community Site Feedback
- I'm not here
I'm not here
06-06-2016 10:51 AM - edited 06-06-2016 10:53 AM
Any ideas why I'm logged in (and posting, obviously) but I don't currently appear in 'Who's Online' or the 'pile of avatars' at the bottom of the Community Homepage (at least I can't see me, I don't know if others can)?
I don't recall changing any settings regarding visibility online and I can confirm that 'Show online status' is set to All here.
I did get a couple of 'Authentication mismatch' warnings earlier when thanking a post - could this be related?
Re: I'm not here
06-06-2016 10:59 AM
Looked at your profile and it says you are offline. You are also not appearing in the online users list like you mentioned. Just checked your settings, all looks fine.
Can you try signing out and back in again?
![](/skins/images/F5BDC76AE3E9E108D06DECB422B09E0B/responsive_peak/images/icon_anonymous_message.png)
Re: I'm not here
06-06-2016 11:02 AM
Yes, the appearance of avatars on that page has and does seem unreliable !.
I hadn't reported this problem, because I keep being told that all my issues with this forum must be some unique fault on my multiple machines or router, and the staff aren't taking fault reports seriously - or at least not providing timely fixes.
Re: I'm not here
06-06-2016 11:05 AM
@jaread83, I'll log out and in but as you can see, I'm able to post OK, thank posts etc. which I couldn't do if really offline.
Re: I'm not here
06-06-2016 11:06 AM
Appears to have worked.
Re: I'm not here
06-06-2016 11:09 AM
I have just taken another look at this, and something has changed !
Until today, if you set your own profile to being 'hidden', you could still see your own avatar in the list of online users, but at the same time other forum users were unable to see your avatar in the list, or whether you were online by viewing your profile to see when you last visited.
Today, I am currently set to 'hidden', and my avatar is not being displayed.
Something about the forum summary page is different, what got changed ?
Re: I'm not here
06-06-2016 12:13 PM
@w23 @jaread83 I've noticed that if I log in on either the Community Home page or the Forum page, my Avatar is not showing. A page refresh resolves that. This behaviour I find strange as clearly the page is being re-loaded as a result of logging in. There is clearly some sort of timing issue here, and of course such issues are abundant with a number of other problems around the forum.
Re: I'm not here
06-06-2016 12:19 PM
Page refresh doesn't work for me.
I dare not try logging out and back in again, as it often takes three or four attempts before my password is accepted, and it feels like luck that I manage to get back in.
Re: I'm not here
07-06-2016 12:39 AM
I haven't changed my settings, or logged out, etc, since my previous post, but my avatar has just reappeared, after being missing for nearly a day !. Weird
Re: I'm not here
20-06-2016 1:01 PM
Even weirder
Re: I'm not here
20-06-2016 2:28 PM
Did you refresh and then it started working again @Anotherone?
Re: I'm not here
22-06-2016 6:36 PM
No I didn't bother refreshing. Here's another one, ha, a pun in every line
I had just logged out They are both from Staging Jack, not that things are any different between here and there as far as this goes, but these serve to illustrate how borked it all is.
Of course a refresh resolves it BUT the damn page has only just loaded as a result of logging out (or in - where that's the case) so a 2nd reload/refresh should not be needed
