Forum signatures
- Feedback
- Community Site Feedback
- Re: Forum signatures
Forum signatures
18-01-2011 11:37 AM
I just want to ask why signatures in graphic form are necessary and what people's opinions are about this?
Is it necessary to have images which appear with every reply? Do people get a bit fed up with seeing the same ones at the end of each response? Bear in mind that it is the content and quality of the reply that we are interested in, not the appendage.
My own view is that a solution to the problem as outlined by Oldjim is to have no graphic signatures at all then there would be no need to be reprimanding members.
What do others think?
18-01-2011 11:45 AM
Quote from: Oldjim Heads up - change of rules regarding signature and image sizes.
As the Plusnet speed tester gives an image of standard size 200 x 100 px and I am getting tired of sending PM's requesting it be reduced to 80 px high we have agreed that the rule can be changed toThe number of standard lines of text have been increased to more or less match the new image size.
Quote Signatures should use no more space than 5 lines of standard sized text would, this includes any blank lines and images you choose to use. Image based signatures should be limited to 100 x 560 pixels and a maximum file size of 40kB.
Since changing the rules I haven't seen any problems.
Besides I like images in signatures
The other factor is the size of text signatures which used to cause problems as well and changing the rule seems to have sorted that one
By all means discuss image based signatures but don't base it on moderators having to take action
18-01-2011 11:51 AM
18-01-2011 1:00 PM
Quote from: poppy Do people get a bit fed up with seeing the same ones at the end of each response? Bear in mind that it is the content and quality of the reply that we are interested in, not the appendage.
Yes yes yes!
Unfortunately, we're in a bit of a minority.
18-01-2011 1:35 PM
Some people may say such images are added by the poster to be amusing or interesting...I beg to differ! Annoying and puerile springs to mind.
18-01-2011 1:41 PM
18-01-2011 1:42 PM
Actually the signature size with images is very little different to your signature size.
Now if we scrapped all signature images and limited sigs to one line of standard text
18-01-2011 1:51 PM
Quote from: Oldjim ....
Sounds interesting especially if we can limit the number of characters used in that one line
18-01-2011 1:55 PM
Quote from: Chris I have an image in my signature which is to follow us on Twitter so I'd like to see them stay.
Your image could be replicated fairly easily with text though – you could set a font size that's greater than the signature default so it still stands out a bit.
18-01-2011 1:58 PM
Quote from: Oldjim @Nick Russell
Touché....how about this now?
18-01-2011 2:54 PM
31-01-2011 12:02 PM
Although I did get told off when mine ran at 5 lines long ... could have pointed out it was an image and didn't need to obey the number of lines rule as it was under 80px high
21-02-2011 3:49 PM
18-03-2011 12:46 AM
18-03-2011 7:41 AM
