Formatting in posts
Mav
Fixes: 518
Formatting in posts
This has happened before but don't remember seeing it posted anywhere...
Basically if you italicise some text that includes a quote then the quote doesn't get italicised and the trailing '' appears in the text.
Everything after the quote is in normal text.
e.g.
Here is some italicised text
with quote
Forum Moderator and Customer
8 REPLIES 8
Gus
Re: Formatting in posts
do any character codes within the quote wrapper
dick:quote
FTTP 500 regrade from Tues 28th November
Mav
Fixes: 518
Sorry, Gus, missed your reply. But I'm not sure I understand the question Undecided
TORPC
@Mav
Can you post an example using the (Code) rather than the (Quote) as it will show how the code gets wrapped
jelv
Fixes: 10
Quoting the original post shows you the code.
[i]Here is some italicised text
[quote] with quote[/quote][/i]
gives you this:
with quote
@mav No need to use code - just wrap [nobbc][/nobbc] round it as I've done!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
[quote] testing[b] testing[/b] testing [/quote]
[i]testing [quote] testing[b] testing[/b] testing [/quote] testing [/i]
[b]testing [quote] testing[b] testing[/b] testing [/quote] testing [/b]
Gives
testing testing testing
testing
testing
testing
testing
So I assume that the effect of a quote is that it nullifies any open formatting
Mav
Fixes: 518
@jelv what does the [nobbc] code do as I can't see anything different between your post and mine except you first showed how I entered the relevant code before displaying the resultant text. Just worked it out Wink
@Oldjim certainly looks that way.
Fixes: 1,495
blasted quotes! Roll_eyes
Fixes: 251
This is in some ways not unlike HTML block level precedence.
[quote] is "block" level formatting whilst [i] is "in-line" level formatting.
In-line level formatting does not / cannot "span" a block level formatting directive.  So...
text
is valid, whereas
text
is not.  Hope this is clear?
