Double details appearing in Avatar block
This screen capture explains it all.
Picture painting a 1000 words, even though that's to many.
9 REPLIES 9
Fixes: 357
Re: Double details appearing in Avatar block
Sorry @Anonymous - I've posed the same question - didn't see yours until afterwards.Embarrassed
JayG
Fixes: 6
Oops, neither did I - threads need merging?
jaread83
Fixes: 81
Yikes. Okay so this is basically what has happened... a while ago - Lithium decided to remove some stuff from the standard component for profiles on post pages including the date registered. Myself and a bunch of other community devs didn't like this and told Lithium to put it back. In the meantime - I had developed a customisation of the missing component as users here has also noticed. Now it looks like they have finally put it back so I need to remove my custom component. I will sort this out by the end of the day.
MauriceC
Resting Legend
Fixes: 17
Glad to find that it is (hopefully) a simple solution Jack.  Smiley
jaread83
Fixes: 81
Okay, I have put a fix in place but the publishing part of Lithium is making me wait around for some automated jobs going off in the background before I can hit the button to publish the changes. Will be fixed soon everyone.
SpendLessTime
Fixes: 86
Looks fixed now.
Appears to be fixed already @jaread83
jaread83
Fixes: 81
Excellent. It looks like the publish queue for the system has been sped up dramatically then as it would sometimes cause the forum to go down briefly. Looks like all is well again Smiley
Fixes: 1,653
*Phew* panic over. Smiley
