Community Username Changed
- Feedback
- Community Site Feedback
- Community Username Changed
07-04-2016 7:10 PM
I seem to have gained a 1 on my username - a little help please ![]()
Re: Community Username Changed
07-04-2016 7:28 PM
07-04-2016 7:45 PM
Pity I didn't see this earlier or the other topic about problems trying to log on. I tried logging on, but it told me I had to reset my password. You were then supposed to send me an e-mail but two hours later I'm still waiting. I tried again just now - same result i.e. no e-mail. Like others, I've had to re-register which means a new user name (penneck1 - no prizes for guessing what it was before PlusNet decided it needed to fiddle). I would like to go back to my old user name, please
Thankyou
07-04-2016 7:50 PM
07-04-2016 7:50 PM
For context, we migrated two separate databases of details to this Community - the forums and blogs were completely separate. It seems that if someone updated their email address on the forum, it didn't update it in the blog database so it means we have two email addresses with the same username so it automatically generates the extra '1'.
As I say - it's not great but we're on to it and will update you tomorrow.
08-04-2016 3:03 PM
Sorry Chris. I received your e-mail about the private message, then accidentally deleted it (clumsy old fool). However, at least I had read it. I can tell you though (1) the e-mail address you were sending to (the selex one) is no good any more because it was my work e-mail address and I retired 6 months ago; (2) the address I had expected to receive on (the one I typed in when I requested the password reset) was my 'graham@penneck.plus.com' one. When I tried the postmaster equivalent, the e-mail from you got through. However, even after doing the password reset, I still have to log in on my new account which requires me to use penneck1 (my new registration username), whilst the username for my original account (which I want to use) was just penneck.
There is one other thing - I don't know how to find private messages. I rarely had need for them over the years, so I have forgotten how to find them. I have spent a while searching the new site without success
Cheers
08-04-2016 3:05 PM
In this case click on your avatar/username at the top right and they will pop out at you
08-04-2016 3:15 PM
I've PM'd you again, hopefully that sorts the issue for you.
09-04-2016 11:20 AM
Like others, my User Name seemed to be invalid, so easiest is just to re-register. I had posted before but not bothered to relink to them. Presume there will be a lot of unused names on the system after a while. Unlike some, and I suspect a minority, my experience of PlusNet is good (I hope that doesn't jinx anything). Otherwise keep up the good work.
12-04-2016 8:17 AM
I got a 1 added to my name too. I changed it back, but have no old posts apparently. I don't care about that but you may want to know that the thing is messed up.
12-04-2016 1:28 PM
@Chilternphil I've located your Plusnet account and searched your old forum username. It has migrated over successfully, could you PM me the email address you've been trying to get the password reset sent to please.
@BurntToast The account with a 1 on the end is related to this.
Your original account seems to be on a gmail address, if you request a password reset to this gmail address you should get access back to the account.
12-04-2016 2:08 PM
How do you do that? There appears to be no log out button which would enable me to start again. I would like to change the email address associated with this forum as in general I don't trust forums to keep email addresses secure. How do I do so please?
12-04-2016 2:42 PM
If you click on your username top right of the forum you will get a fly-out menu. The last item on that menu is for signing out.
You should then be able to start again with the gmail address referred to in the previous reply. Once you've reset the password for your original username, login, click your username and select My Settings. The second tab there allows you to change your email address.
12-04-2016 2:51 PM - edited 12-04-2016 3:09 PM
Actually that doesn't work. Firstly, the fly out bit flies out and back so quick most times that I can't catch it. After many attempts it did stay out and I hit sign out and it came up with an error page and hasn't signed me out at all. LOL. Quite funny really.
Here's another bug. HIt Post options in order to edit the post and the page flies to the top, have to then scroll down to find the post again.
I have found now that to get the fly out bit to stay out I have to hit right at the top above the avatar by my name. If I hit just too low it doesn't stay out. Finding the sweet spot is key but is not intuitive.
12-04-2016 3:14 PM
Oh dear, these are features of the mysterious bugs that crept into this forum on Friday morning - but don't appear on the staging site. ![]()
You might be able to get signed out if you can open "sign out" in a new tab.
