Community Site Bug Fix Progress 13/02/08
jwing
Re: Community Site Bug Fix Progress 13/02/08
Quote from: jelv
Can you do anything about the blank image placeholder for people who used to have avatars - there is no clean way of removing them I could find.
That wont happen on live, its just because it can't find it on the beta site Cheesy
Jonny
jelv
Fixes: 10
How do you remove your avatar as opposed to replacing it with a new one?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Colin
Personalised Pic - (No Pic)
pierre_pierre
Quote from: jwing
Quote from: jelv
Jonny
not really certain which forum you are referring to live or beta, but for instance Poppy has the blank one on live, Orbrey has a picture
jelv
Fixes: 10
Well spotted sir! Here's a link to a post showing the blank image placeholder on the live forum:
http://community.plus.net/forum/index.php/topic,60896.msg494351.html#msg494351
pierre_pierre
now Chillypenguins got one on live
Poppy's avatar has always appeared like that (the only difference being the outline on this skin)
The reason some work on beta and some don't is that the uploaded ones haven't been copied across to the beta site. (ones linked to hosting outside the CS work fine)
The reason Chilly's avatar isn't working on live is because he hosts it on his own server at home, which throws the occasional wobbly.
Colin
These have now rolled live...
Kelly
Fixes: 9
Yay.  Big Avatars again Cheesy
Kelly Dorset
Ex-Broadband Service Manager
Colin
Indeed Smiley
Cleared out to 'resolved'
