Community Site Bug Fix Progress 13/02/08
jwing
Re: Community Site Bug Fix Progress 13/02/08
Quote from: James_H
Wierd - not what I saw entierly!
Anyway, next bug to report.
The "Go" button next to the "Jump to" dropdown doesn't stay to the right on Polls.
http://community.beta.plus.net/forum/index.php/topic,57980.0/topicseen.html
Scroll to the bottom, and you'll see that the button is centred underneath the dropdown for some reason.
Only appears to happen on polls.
Image sent from "James_h" as he is having problems with his box so am uploading it for him, see below. Looks like it might be IE6 related, will see what we can do.
Jonny
Quote from: jwing
Jonny
Nah its on, IE 7.0.5730.11
Must remember to add a rule to the firewall to allow me to upload pictures...
Cheers for adding it Jonny.
jelv
Fixes: 10
Does turning quick reply on make a difference? (that appears under the jump line).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jwing
Quote from: James_H
Thats really odd as i have the same version of IE7 and i am unable to reproduce it? Will check on a couple more machines to confirm.
No probs about uploading the the image Wink
Jonny
jelv
Fixes: 10
Just realised: It's because you are a moderator and there's not enough room on that line.
Simple fix is to put the moderators options on a line on their own (or wrap Jump to to the Go button in non break tags)
Makes sense! I bow to your superior bugfixing abilities Mr Jelv.
zubel
Or just stop him being a moderator?
Grin
B.
jwing
Hi Guys,
Just another quick update. We have now also fixed the following bugs/issues as of this morning and will be rolled to the Community Beta site soon:
- When posting a comment on a news item or blog the returns are taken out (DONE)
- Comments links don't link directly to the comments (DONE)
- Look at a link to get back to the portal (in addition to logos) (DONE)
- Front Page - picture placement is a bit wrong in the announcements section (DONE)
- Sort out sub board icons (DONE)
- Formatting of search results screen is broken (goes over right hand margin) (DONE)
Will let you know when these are on the community beta site.
Jonny
Oldjim
Resting Legend
Fixes: 63
One possible improvement which seems to have been missed is to provide a link at the bottom of the page to Unread Posts to avoid having to manually scroll back to the top
jelv
Fixes: 10
I had suggested putting them on the same line as the Jump To. But I now realise that from James' problem that that is where the Moderators options go - so it depends on what they do with that.
jwing
Quote from: Oldjim
Will add it to the list for something to look at in the furture, as this is not really a bug  but a potential improvement.
Jonny
jwing
Were just trying to add the new fixes to the Community Beta site at the moment so you might see some odd things happening on there (e.g. stuff breaking randomly) So please bear with us. Will let you know when its all on there shortly.
Jonny
jelv
Fixes: 10
Thought no-one would notice did you? Wrong!
(For everyone else I think Jonny's post was prompted by me contacting Colin regarding the "Unable to load the 'main_above' template." error I was getting)
jwing
Everything should be ok now on the Beta site, and all fixes we have said are fixed are now on there.
thanks
Jonny
PS. I noticed it just before you messaged colin as the blog posts page on the front was broken as we hadnt activated a plugin Wink
jelv
Fixes: 10
Can you do anything about the blank image placeholder for people who used to have avatars - there is no clean way of removing them I could find.
