Can't login - cookie settings??
- Feedback
- Community Site Feedback
- Re: Can't login - cookie settings??
13-02-2012 8:33 PM
Each time I type my username and password in I get a message saying "You were unable to login. Please check your cookie settings"
I have just tested logging into other forums that I use and none of them have had any issue and have let me in with no problems.
Can someone please give me a clue where to start.
13-02-2012 9:47 PM
I suspect that it won't allow two logins at the same time even though the first computer isn't connected
13-02-2012 10:38 PM
13-02-2012 10:44 PM
13-02-2012 10:58 PM
14-02-2012 7:21 AM
or did you mean you cant get on the internet with the XP
14-02-2012 8:11 AM
I'd advise to try another one anyway. Firefox or Chrome are both quick and easy to install and remove afterwards.
Also I'm assuming you've tried the basics like deleting the cache of cookies on that machine.
14-02-2012 9:42 AM
I think I will just flatten it again tonight and rebuild it unless anyone comes up with any other suggestions.
14-02-2012 10:04 AM
Could there be anything in your cookie settings preventing the login? If you open tools -> Internet Options and go to the privacy tab, then hit the 'sites' button there may be some URLs listed there, or if not there then in the box that appears when hitting the 'advanced' button?
14-02-2012 12:27 PM
14-02-2012 4:39 PM
14-02-2012 9:21 PM
![Cool Cool](/html/@C99FFF55540079D701B20BB503070F3D/images/emoticons/cool.gif)
Never mind, I have enjoyed the last 5 hours of installing the OS and the anti virus and all of the microsoft patches
![Grin Grin](/html/@DD2C576E9659EC19DB321D3F15B5069C/images/emoticons/grin.gif)
14-02-2012 9:25 PM
- Feedback
