Adding words to the spell checker
Alex
Fixes: 13
This is just an idea.
When using the spell checker which I think works generally fine, I've noticed words I think that should be in there which aren't. I can't remember the ones I found now (yes, I know that's helpful - sorry). I assume the forum software admin page will let a mod or admin to manually add ones in?
I was wondering whether to start a thread (ok well I have now). On words people think should be added? What do you think - then I guess it'll need PlusNet and mod approval before it is added?
Yes I know we can't have anything dodgy such as swears, words or acronyms of ones, not family friendly words etc. The ones I did find were innocent ones - honest Angel
12 REPLIES 12
Oldjim
Resting Legend
Fixes: 63
Re: Adding words to the spell checker
do you actually mean the spell checker or what used to be called the swear filter
Pete11
Seasoned Pro
Fixes: 4
I found the same thing with other spell-checkers and I'm wondering if it's set to English U.S. rather than English U.K.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Alex
Fixes: 13
Yes I meant the spell checker not swear filter.
Works both ways I guess - if we post a word which is not in the spell checker, admins can decide to add it to spell checker, not to, or it should go in the swear filter instead Tongue
No but being serious, they were not sweary words.
Mav
Fixes: 518
If you do mean the swear filter then use the Report to Moderator for any words you feel are inappropriate and they will be discussed with staff and added if deemed necessary.
Forum Moderator and Customer
Alex
Fixes: 13
@Mav
I wasn't referring to the swear filter - I am talking about the spell checker not picking up innocent words I checked I had spelt correctly.
Strat
Fixes: 565
That will be the spell-checker in your browser then.
Alex
Fixes: 13
Strat
Fixes: 565
I must confess I had completely forgotten about that as I've used my browser spell-checker for so long Embarrassed
Alex
Fixes: 13
Yep no worries. It doesn't happen very often and generally works fine, but there were a few I noticed (about 3 I think).
Probably best to PM a mod if I find another one?
Not the end of the world I know. Always alternatives - Ctrl C, Ctrl V into Word, spell check and Ctrl C, Ctrl V back into your post. That's what I used to do when we used SMF. Tongue
Just trying to be helpful.
Alex
Fixes: 13
Here's two to start you all off (this is like a quiz, I know you're all excited Tongue).
From my last post:
Ransomware
Malware
rongtw
Fixes: 12
its odd sometimes like Online dont work , the spellcheck offer no alternative for online which it says is spelt wrong
jaread83
Fixes: 81
We can't add words to the spell checker unfortunately. However, we do have the option to let your own browser deal with spell checking (which you can add words in yourself) - maybe this would be worth a try? Shame you can't set this per user.
