Peak time latency spikes
Re: Peak time latency spikes
@jamesanstee - similar result to mine on the same gateway !
englishrick
Well its download has gone up a bit but upload is now down on the last one.still not good enough though....tooo late though as im up @ 5am for work...still on pcl-ag01
1. Best Effort Test:  -provides background information.
Download Speed
58.63 Mbps
0 Mbps 74.02 Mbps
Max Achievable Speed
Download speedachieved during the test was - 58.63 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-74.02 Mbps .
Additional Information:
IP Profile for your line is - 74.02 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
9.66 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 9.66Mbps
jamesanstee
Quote from: purleigh
Being on the elevated product that plusnet have put me on has made no difference at all .
chrispurvey
@jamesanstee & purleigh
Can you both try and hop onto another gateway?
AndyH
Can I jump too or is dave checking my connection still?
Any gateway, or are there some we should avoid ?   Huh
rookey
Quote from: AndyH
@ rookey
How do you get on with these tests: http://www.bbc.co.uk/iplayer/diagnostics http://www.thinkbroadband.com/speedtest.html
BBC link does not work Sad
Bjn
10pm and as normal back to normal, problem for me allways appear betweem approx 8-10pm
@rookey - that BBC link worked for me  Undecided
rookey
Will check again tmr off to bed now
chrispurvey
Quote from: AndyH
Go for it. Let us know how your connection is.
rookey
Shame my connection wasn't checked at the low download I had under 1mb jeeze
AndyH
More test results (on PCL-AG03 before jumping):
Download Speed (Mbps): 8.16
Upload Speed (Mbps): 10.22
Ping Latency (ms) 39.50
Download Speed 8396 kbps
Streaming Speed (1) 2784 kbps
Streaming Speed (2) 3010 kbps
Streaming Speed (3) 2914 kbps
bifkinuk
Quote from: chrispurvey
Quote from: AndyH
and me?
chrispurvey
@bifkinuk
Yes please.
