Peak time latency spikes
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
13-03-2013 9:59 PM
13-03-2013 9:59 PM
1. Best Effort Test: -provides background information.
Download Speed
58.63 Mbps
0 Mbps 74.02 Mbps
Max Achievable Speed
Download speedachieved during the test was - 58.63 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-74.02 Mbps .
Additional Information:
IP Profile for your line is - 74.02 Mbps
Upload Speed
9.66 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 9.66Mbps
13-03-2013 10:05 PM
Quote from: purleigh @jamesanstee - similar result to mine on the same gateway !
Being on the elevated product that plusnet have put me on has made no difference at all .
13-03-2013 10:06 PM
Can you both try and hop onto another gateway?
13-03-2013 10:07 PM
13-03-2013 10:07 PM
13-03-2013 10:08 PM
Quote from: AndyH @ rookey
How do you get on with these tests: http://www.bbc.co.uk/iplayer/diagnostics http://www.thinkbroadband.com/speedtest.html
BBC link does not work
13-03-2013 10:09 PM
13-03-2013 10:09 PM
13-03-2013 10:10 PM
13-03-2013 10:10 PM
Quote from: AndyH Can I jump too or is dave checking my connection still?
Go for it. Let us know how your connection is.
13-03-2013 10:11 PM
13-03-2013 10:11 PM
Download Speed (Mbps): 8.16
Upload Speed (Mbps): 10.22
Ping Latency (ms) 39.50
Download Speed 8396 kbps
Streaming Speed (1) 2784 kbps
Streaming Speed (2) 3010 kbps
Streaming Speed (3) 2914 kbps
13-03-2013 10:14 PM
Quote from: chrispurvey
and me?
13-03-2013 10:16 PM
Yes please.
