Peak time latency spikes
walterhornby
Re: Peak time latency spikes
Quote from: dvorak
suspect they're not on static ip and the IP address changed..
If you mean me, then yes, not on a static ip.
Anotherone
Champion
Fixes: 21
@walterhornby
You need to go to TBB and delete your old monitor and create a new one.You will need to do that every time your IP address changes ie. everytime you Gateway Hop or lose connection.
walterhornby
OK, will do, and thanks. Must start reading things a bit more than I do, as the site does mention problems with dynamic IP's.
jim:quote
HNKS
Absolutely sick of how inconsistent this so called fibre is.
Anotherone
Champion
Fixes: 21
It isn't only affecting Fibre, although in some cases some Fibre users are showing the largest degradation. Have you tried Gateway hopping?
ITWorks
Fixes: 9
Come peak time again the slow speeds and increased pings ( was getting 50 - 58 ping,  6.3mb)  Sad , this is happening almost every night over the last few weeks for me, the only way i do not get this is by not using my connection at peak times. So time to gateway hop
gateway ptn-ag01
Then on to ptw-ag02
Then on to gateway pcl-ag07 , speed is getting better , ping is getting higher
Then on to gateway pcl-ag08 lower speed and lower ping
Then on to gateway pcl-ag02
Then on to  gateway ptn-ag03
Then back to gateway pcl-ag08
After 15 mins from been off the above gateway , it seems to be working ok for the moment .
Six gateway hops to six different gateways and all not performing as they should.
PN i hope this is sorted soon, this is becoming more and more frustrating.
Regards
Mike
wykehamhouse
We are getting slow speeds in peak times too. The actual internet speed is fine, but the web browsing speed is really slow (it comes and goes). We have tried gateway swapping multiple times but it doesn't help.
Anotherone
Champion
Fixes: 21
Anyone got a TBB monitor who is on pcl-ag01? It looks as though something may have kicked off just before 5.00pm for about 2 hours - on a 21CN connection anyway.
shalom2010
Seems fine on PTW-AG03 Gateway
ITWorks
Fixes: 9
An hour later (gateway pcl-ag08) all slow again and increased pings  Angry
Regards
Mike
w23
Fixes: 4
pcl-ag03, no latency issues at all BUT:
(Used to 50Mb/s+)
Call me 'w23'
jamesanstee
Im not experiencing any slow downs both yesterday and today has been perfect.
austinsom
I'm on pcl-ag03 tonight, which has so far been ok:
Jitter a bit off, but acceptable:
TBB graph shows some nasty spikes and packet losshowever - as I seem to lose sync overnight, I have posted a snapshot rather than a live graph:
Bjn
After 2 days of no problems a drop in speed tonight, gateway hoping not much help tried 4 different ones, could do this all night but speed results the same. Speed all over the place from my full 52Mb down to under 2Mb, yoyoing all evening between high & low speeds. Test on speedping.net shows A grade line even at low speeds . I've had no problems until about a week ago I hope someone can get this sorted asap as when we need the bandwidth in the evening it's not there.
Now ended up on pcl-ag01 which seems OK at 11pm but by this time each night  the problem is normally over, lets see what tomorrow brings.
Update
6.25am on 4.3.13 speed tests all 51 to 52Mb everything seems to be running at max, so my problem seems to happen between 4pm and 11pm and speed slows down for a 2 hours slot drops as low as 2Mb  still on gateway pcl-ag01. Lets seem what tonight brings.
w23
Fixes: 4
Quote from: jamesanstee
Could you say which gateway you're on please?
http://usertools.plus.net/@gateway/
Call me 'w23'
