Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
18-02-2013 8:21 PM
You are currently connected to the gateway known as pcl-ag03
Going to jump gateway
Edit: Now back to normal
You are currently connected to the gateway known as pcl-ag05.
Regards
Mike
18-02-2013 8:25 PM
18-02-2013 8:26 PM
Im on gateway known as pcl-ag03 also .
Quote from: jamesanstee It's not allowing me to do a further diagnostic as the page is timing out .
18-02-2013 8:31 PM
Ex-Plusnet Jobsbody
18-02-2013 8:35 PM
I'm hitting 40+ pings and DL speed is crippled down to 30Mbps. Should be 60Mbps.
I'm on PTW-AG04
18-02-2013 8:41 PM
18-02-2013 8:46 PM
Ex-Plusnet Jobsbody
18-02-2013 8:49 PM
Not sure if ive done this path ping correctly
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>pathping www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.70]
over a maximum of 30 hops:
0 No resources.
C:\Users\Private>
18-02-2013 8:58 PM
18-02-2013 9:01 PM
Quote from: jamesanstee Not sure if ive done this path ping correctly
0 No resources.
That is because you need to run the CMD window with admin privs. Try just a tracert instead.
Ex-Plusnet Jobsbody
18-02-2013 9:03 PM
18-02-2013 9:06 PM
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.90]
1 1 ms 1 ms 1 ms 192.168.1.1
2 11 ms 12 ms 12 ms lo0-central10.ptn-ag04.plus.net [195.166.128.193
3 12 ms 13 ms 13 ms link5-central10.ptn-gw01.plus.net [84.93.248.232
4 12 ms 12 ms 12 ms xe-10-1-0.ptw-cr01.plus.net [212.159.1.44]
5 22 ms 17 ms 18 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
6 * * * Request timed out.
7 13 ms 13 ms 14 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
8 13 ms 14 ms 15 ms 132.185.255.165
9 12 ms 13 ms 12 ms bbc-vip011.cwwtf.bbc.co.uk [212.58.246.90]
Trace complete.
C:\Users\Private>
18-02-2013 9:07 PM
Quote from: fagin This is rocking..... pings over 50ms now.
That isn't a bad ping ordinarily. What do you usually get?
Ex-Plusnet Jobsbody
18-02-2013 9:10 PM
Youtube is like watching someone doing the stutter rap.
18-02-2013 9:13 PM
