Peak time latency spikes
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
01-03-2013 10:02 PM
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=346ms TTL=243
Reply from 212.58.241.131: bytes=32 time=227ms TTL=243
Reply from 212.58.241.131: bytes=32 time=314ms TTL=243
Reply from 212.58.241.131: bytes=32 time=287ms TTL=243
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 227ms, Maximum = 346ms, Average = 293ms
C:\Users\X>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
1 * 23 ms 139 ms dsldevice.lan [192.168.1.254]
2 220 ms 53 ms 19 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189]
3 186 ms 22 ms 18 ms link1-central10.pcl-gw01.plus.net [84.93.249.224]
4 363 ms 235 ms 292 ms xe-2-2-0.pcl-cr01.plus.net [212.159.1.12]
5 322 ms 282 ms 430 ms ae2.pcl-cr02.plus.net [195.166.129.7]
6 231 ms 443 ms 225 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 307 ms 434 ms 428 ms ae1.ptw-cr01.plus.net [195.166.129.0]
8 285 ms 419 ms 271 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
9 * * * Request timed out.
10 264 ms 300 ms 499 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
11 414 ms 267 ms 192 ms 132.185.255.60
12 190 ms 198 ms 322 ms virtual-vip.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
01-03-2013 10:04 PM
01-03-2013 10:06 PM
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ping bbc.co.uk
Reply from 212.58.241.131: bytes=32 time=18ms TTL=246
Reply from 212.58.241.131: bytes=32 time=17ms TTL=246
Minimum = 17ms, Maximum = 18ms, Average = 17ms
C:\Windows\system32>tracert bbc.co.uk
1 46 ms 98 ms 98 ms dsldevice.lan [192.168.1.254]
2 20 ms 18 ms 19 ms lo0-central10.ptw-ag03.plus.net [195.166.128.197
3 19 ms 18 ms 17 ms link10-central10.ptw-gw02.plus.net [84.93.248.82
4 17 ms 17 ms 18 ms xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
5 17 ms 17 ms 17 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 17 ms 16 ms 17 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 64 ms 18 ms 18 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
9 22 ms 17 ms 22 ms 132.185.255.60
10 17 ms 18 ms 17 ms virtual-vip.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
Only Usenet affected here
01-03-2013 10:06 PM
I am new to Plusnet. Just got mine activated today.
Wow, isn't this a throwback to Entanet-esque shenanigans? I didn't think i'd see the day.
Anyway, I am on gateway pcl-ag06. Ping times and speeds are normal. I WAS on pcl-ag07 and it was absolutely dire (200ms pings, 3mb speeds)
I reckon what has happened is Plusnet have probably got an influx of new customers and it's hammering their systems.
01-03-2013 10:09 PM
I just hopped briefly onto pcl-ag07 and it was atrocious:
So hopped again onto ptn-ag03 and it's slightly better, although a long way from my 70mb down, 9ms ping.
01-03-2013 10:16 PM
Even ADSL was 10x faster lol
01-03-2013 10:20 PM
As you are on Fibre it's not so critical with the router, but it could be disastrous for an ADSL user depending on their connection.
But those speeds are really bad. Try another Gateway hop. Also run http://speedtest.btwholesale.com/ ignore the red pre-amble except make sure nothing else is using the Internet, after the first test Click Further Diagnostics, enter your phone number and run the test.Copy and paste the result.
01-03-2013 10:23 PM
01-03-2013 10:24 PM
01-03-2013 10:27 PM
http://www.thinkbroadband.com/ping/share/660bb73c13549817d7f965387a399f8e.html
Looks like we've had something push that same device again into failure. Just called someone to sort it. This would have affected anyone on pcl-ag08, pcl-ag07.
Ex-Plusnet Jobsbody
01-03-2013 10:29 PM
01-03-2013 10:42 PM
Quote from: Kelly I just got in and checked the graphs and spotted this:
It wasn't me guv honest
01-03-2013 10:56 PM
01-03-2013 11:17 PM
01-03-2013 11:20 PM
Ex-Plusnet Jobsbody
