Gateway Checker Update
Re: Gateway Checker Update
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
core3-te0-0-0-14.faraday.ukcore.bt.net (213.121.193.160) 3.054 ms
acc1-te0-0-0-1.l-far.21cn-ipp.bt.net (109.159.249.50) 2.900 ms
peer2-ae-1.redbus.ukcore.bt.net (195.99.126.97) 3.840 ms
ae1.ptw-cr01.plus.net (195.166.129.0) 4.795 ms
ae2.ptw-cr02.plus.net (195.166.129.5) 4.622 ms
link11-central10.pcl-gw01.plus.net (84.93.249.212) 4.028 ms
Fixes: 75
Thanks for the report.
David
David
link12-central10.pcl-gw02.plus.net (84.93.249.54) 1.696 ms
Fixes: 75
Thanks, that IP is on the list. Smiley
David
David
And another:
link3-central10.pcl-gw01.plus.net (84.93.249.196) 4.795 ms
Disconnected earlier to run the BT wholesale speed test login as my Fibre connection was atrociously slow at 9:30pm compared to earlier in the day.
First attachment is normal test, second is the TAP3 wholesale login test.
The above is the new gateway that I am logged in on now and testing isn't much better.
core3-hu0-3-0-0.faraday.ukcore.bt.net (213.121.193.160) 3.092 ms
acc2-te0-0-0-11.l-far.21cn-ipp.bt.net (109.159.249.178) 3.180 ms
195.99.126.99 (195.99.126.99) 38.792 ms
ae1.ptw-cr02.plus.net (195.166.129.2) 2.622 ms
link12-central10.pcl-gw02.plus.net (84.93.249.54) 5.456 ms
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 75
Thanks. That IP is on the list for correction. Smiley
David
David
Fixes: 25
Another IP address to add to my list in reply #131
195.166.130.221 ptn-bng01
The usertools gateway checker gives:
    195.99.126.139 (195.99.126.139) 3.721 ms
    link11-central10.pcl-gw01.plus.net (84.93.249.212) 4.593 ms
Which was already reported.
Fixes: 12
I just got this
    195.99.126.139 (195.99.126.139) 2.949 ms
    link11-central10.pcl-gw01.plus.net (84.93.249.212) 3.901 ms
Fixes: 75
Thanks to both of you for those reports. Smiley
David
David
Which gateway
195.99.126.139 (195.99.126.139) 2.760 ms
link11-central10.pcl-gw01.plus.net (84.93.249.212) 3.924 ms
Fixes: 75
Thanks, that one is on the list. Smiley
David
David
Seasoned Pro
Is this?
core4-hu0-3-0-0.faraday.ukcore.bt.net (213.121.193.164) 3.609 ms
acc2-10GigE-0-5-0-0.l-far.21cn-ipp.bt.net (109.159.249.160) 5.124 ms
195.99.126.99 (195.99.126.99) 58.050 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 6.806 ms
ae1.ptw-cr01.plus.net (195.166.129.0) 6.807 ms
link11-central10.pcl-gw01.plus.net (84.93.249.212) 7.902 ms
Fixes: 75
Thanks; yes it is. Smiley
I think that gateway is ptn-bng01.
David
David
