Community Update - Changes are coming!
Fixes: 45
Re: Community Update - Changes are coming!
For your sake I just hope your wife doesn't read this post, but maybe you'd suit the 'Panda Look'.
Fixes: 4
Mrs w23 probably doesn't know our broadband is supplied by Plusnet, let alone that they have a community & forum, her 'internet world' is pretty much Facebook only.  Wink
Call me 'w23'
Just got my email from PN. It asks us to reset our password. Can we retain the existing password or do we need to change it?
Fixes: 167
You'll need to reset it which is why it's very important that you check the email address in your profile is up to date.
 Chris Parr
 Plusnet Staff
I think the question being asked is can it be reset to what it is currently?
Fixes: 167
If you want to, then that shouldn't be an issue.
 Chris Parr
 Plusnet Staff
Thanks Chris, that is what I was asking.
NorthEasterner
How do we change our username like mentioned in the previous posts when the migration is complete.
Many thanks Wink
Ex Plusnet Fibre customer. TalkTalk Fibre Customer using a TalkTalk WiFi Hub. If you wish to say thanks, please click the thumbs up :thumbsup:
Fixes: 167
That will be explained on the new site, there's no point in me going through how to do it now tbh.
 Chris Parr
 Plusnet Staff
rongtw
Fixes: 12
I just got my Email too , Thunderbird says its Dangerous  Cheesy
Fixes: 5
I suspect that happens because the email fields "From:", "Reply-to:", and "Return-Path:" are all different !
and the body of the message contains links to multiple other domains.
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.4.4-p3 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
VileReynard
Champion
Fixes: 17
Since non-subscribers can post to this new forum will I be able to have a multitude of accounts, for no particular reason?
Fixes: 167
No, I believe multiple accounts will be covered in the rules.
 Chris Parr
 Plusnet Staff
VileReynard
Champion
Fixes: 17
When will the rulebook be issued?
Fixes: 167
When the site is launched. The majority of the rules are similar to here IIRC.
 Chris Parr
 Plusnet Staff
