BT Speed Test Result
- Business
- Re: BT Speed Test Result
25-03-2010 2:02 PM
What does the bold 2000 Kbps imply in an up to 8Mbs product
Is the line capped at 2Mbs?
Quote from: BT Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1142 Kbps
0 Kbps 2000 Kbps Max Achievable Speed
Download speedachieved during the test was - 1142 Kbps
For your connection, the acceptable range of speeds is 800-2000 Kbps.
Additional Information:
Your DSL Connection Rate :1824 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps.
Message 1 of 5
(3,066 Views)
4 REPLIES 4
25-03-2010 3:58 PM
Update.
Dropped a ticket into the 19 hour queue and it was answered within 4 hours.
The requested SNRM reset done with a drop to 6.5 with D/L speed climbing up past 2.5Mbs.
Brilliant service ( it is a business line though )
Message 2 of 5
(515 Views)
26-03-2010 10:58 AM
If anyone happens to be passing can they give my PN profile a kick to match the BT one
Message 3 of 5
(515 Views)
26-03-2010 5:02 PM
Hi fcel,
I've update our profile for you to 2000, to match the two profiles up. May need a single one-off reboot of the router to pick up this profile.
Message 4 of 5
(515 Views)
29-03-2010 8:04 AM
Thanks Jake.
Message 5 of 5
(515 Views)
