wifi extension
- Re: wifi extension
wifi extension
24-07-2025 4:04 PM
Hi
I will be setting up my Plusnet broadband connection in the next few days. Do they sell / supply any extension devices for use in the home? With my current provider I have the router and two extension discs for use throughout my house.
Brian.
Message 1 of 4
(816 Views)
3 REPLIES 3
Re: wifi extension
24-07-2025 4:08 PM
@Brian463 No they don't, but there are people on here who can suggest options, should you find you need wider coverage.
Re: wifi extension
25-07-2025 1:45 PM
if your current discs are not network locked, you may be able to reconfigure to PN's settings.
Message 3 of 4
(731 Views)
Re: wifi extension
27-07-2025 5:14 PM
Thanks. I'll try that.
Message 4 of 4
(674 Views)
