wifi extension
Brian463
wifi extension
Hi
I will be setting up my Plusnet broadband connection in the next few days. Do they sell / supply any extension devices for use in the home? With my current provider I have the router and two extension discs for use throughout my house.
Brian.
3 REPLIES 3
Fixes: 387
Re: wifi extension
@Brian463 No they don't, but there are people on here who can suggest options, should you find you need wider coverage.
Gel
Champion
Fixes: 29
Re: wifi extension
Brian463
Re: wifi extension
Thanks. I'll try that.
