using my own router
- Re: using my own router
using my own router
25-05-2013 3:39 PM
what do i need to use my own router instead of this technicolour one?
im assuming a username and password to go on the new router anything else?
Message 1 of 6
(1,743 Views)
5 REPLIES 5
25-05-2013 3:58 PM
The settings for your own router can be found here:-
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Message 2 of 6
(629 Views)
27-05-2013 4:46 PM
thanks ill see if ican find somewhere to put that info
Message 3 of 6
(629 Views)
28-05-2013 5:05 PM
Us staff may not be able to do this but if you can post the make and model of the router some of the ever-so-knowledgeable community bods may be able to give you some guidance if you need it.
Adam
Adam
Message 4 of 6
(629 Views)
31-05-2013 8:43 PM
its a sagemcom sagem f@st 2504n (sky)
i flashed it with a custom firmware that unlocks hidden menu's but not looked at it proper yet.
i never had a single problem with it ever
Message 5 of 6
(629 Views)
16-05-2014 8:01 AM
what firmware did you use? can you give me a link to firmware
Message 6 of 6
(629 Views)
