upload speed
- Re: upload speed
upload speed
02-12-2014 10:47 AM
i think my upload is getting wrost it was 18mb now its getting around 2.50mb i play Final fantasy XIV online i noticed alot of lag becuse of upload gone down
Message 1 of 8
(833 Views)
7 REPLIES 7
Re: upload speed
02-12-2014 12:26 PM
Hi David,
I've just been running some diagnostic checks which don't show any obvious causes for this at all.
I'm assuming you saw those speeds when using a wired connection?
I was about to advise you to raise a fault but see you've done so already
Bear with us and out faults guys will pick that up ASAP for you.
Message 2 of 8
(465 Views)
Re: upload speed
02-12-2014 4:02 PM
its upload speeds are crap then ever i had with bt and plusnet when i have net
Message 3 of 8
(465 Views)
Re: upload speed
02-12-2014 4:02 PM
yes it is wired connection i am not happy with plusnet at this time they never say what the problem is i think soon is better to leave plusnet i never recomand anyone to here i used to but tickets is open the last time over 14 days untill i get a open rech person out i think the connection need a hard reset call
Message 4 of 8
(465 Views)
Re: upload speed
03-12-2014 12:39 PM
I see you've created a fault ticket, we'll get that picked up and tested asap.
Is the upload slow at all times or is it specific times of the day?
Message 5 of 8
(465 Views)
Re: upload speed
03-12-2014 12:49 PM
its all the time upload speeds are around 2.50 to 3mb is it the server i am on that is downgraded over time i did a ip look on plusnet the domain is caneese.plus.com
Message 6 of 8
(465 Views)
Re: upload speed
04-12-2014 11:59 AM
From your comments on a different thread I believe this is now resolved?
Message 7 of 8
(465 Views)
Re: upload speed
04-12-2014 12:02 PM
yes Chris it was the bt home hub 4 that gone on me i am not paying £135 for a new one
Message 8 of 8
(465 Views)
