suddenley lost most of my speed
- suddenley lost most of my speed
04-04-2010 11:15 AM
Hi, Just have lost most of my speed, here are my router stats
System Up Time 00:56:25
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 22696 27444 0 1118 5012 00:55:38
LAN 10M/100M 28689 23584 0 5209 1279 00:56:20
ADSL Link Downstream Upstream
Connection Speed 6336 kbps 448 kbps
Line Attenuation 32 db 10 db
Noise Margin 11 db 19 db
and here is the BT Checker results: Download speed 83 Kbps acceptable range 50-250 Kbps DSL connection rate 6336 Kbps downstream
and 448 Upstream and IP profile for my line is 135 Kbps.
On Thursday it was all bombing along nicely but now as you can see it's awful, any ideas you nice people Thanks Del
Message 1 of 2
(534 Views)
1 REPLY 1
Re: suddenley lost most of my speed
04-04-2010 5:46 PM
Hello,
Ive got the same problem but mine was due to a faulty wire now my BT IP Profile is incredibily slow
A few other things that may affect speed:
1. Have you rebooted your router a lot of times
2. Has there been problems with your router (you can check your log for more info)
3. Is it plugged into the master socket
4. Have you recentley changed your wiring setup or added new items onto the master socket (i.e Extention Sockets from the master socket ect)
Regards
Aman
Regards
Aman
Message 2 of 2
(264 Views)
