speed limited to 2Mbps
- Re: speed limited to 2Mbps
15-04-2012 1:32 PM
for the last week my speed has not gone above 2Mbps
bt speedtester gives me this error
"The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
Message 1 of 8
(1,553 Views)
7 REPLIES 7
15-04-2012 1:36 PM
Other than the BT speedtest can you give the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
Message 2 of 8
(669 Views)
16-04-2012 10:41 AM
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 39.5 db 19.0 db
Noise Margin 9.4 db 21.0 db
and bt speedtester is still not working for me
Message 3 of 8
(669 Views)
16-04-2012 10:45 AM
And this one https://portal.plus.net/my.html?action=data_transfer_speed
Also see if this works http://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Message 4 of 8
(669 Views)
16-04-2012 10:54 AM
I just used dmt tool as suggested here http://community.plus.net/forum/index.php/topic,101910.msg864847.html#msg864847 when I last had this problem ( but not a router compatible with dmt tool) and 10 minutes later it's working properly
more info on dmt tool can be found here http://www.kitz.co.uk/routers/DMTv8.htm if anyone else has a similar problem
Message 5 of 8
(669 Views)
16-04-2012 2:42 PM
Hi iambatman,
I've just been on to our suppliers who've identified a profile mismatch. This should be rectified within 2 hours, so If you can let me know how it is later.
Jojo
Jojo
Message 6 of 8
(669 Views)
16-04-2012 7:11 PM
it was back to normal from 11am until now - I'm now limited to 2Mbps again
Message 7 of 8
(669 Views)
17-04-2012 10:16 AM
Hi iambatman,
There's nothing showing on diagnostics now. I'd suggest finishing answering the questions on your fault ticket and see what the faults team can come up with.
Jojo
Jojo
Message 8 of 8
(669 Views)
