speed issue
- Re: speed issue
speed issue
21-06-2013 12:55 PM
Telephone number:
xxxxxxxx
Phone exchange:
BURROWBRIDGE
Estimated line speed:
1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-31 14:14:40
Current line speed:
7.15 Mb
Download speedachieved during the test was - 0.82 Mbps
For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
Additional Information:
Your DSL Connection Rate :1.38 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.75 Mbps
Why has my profile and speed been reduced as my speed is now below reasonable use for i player and skype
Message 1 of 7
(1,016 Views)
6 REPLIES 6
Re: speed issue
21-06-2013 1:24 PM
Hi stathe,
From what I can see your line profile has been around 1Mb since March, possibly before but that's as far back as our supplier's speed records for your line go. There was a drop on your line yesterday morning, perhaps that led to a drop in sync speed - if you resync the connection around lunchtime (if you see this in time try this lunchtime maybe?) you should get a resync at the best speed your line can handle which should improve things, sync speed is usually higher around lunchtime for some reason.
Hope that helps, and also that the speeds pick up.
Message 2 of 7
(450 Views)
Re: speed issue
21-06-2013 3:57 PM
Will try to-morrrow , but fear that when I try to resynch that it will count as a disconection and make it worse,
Message 3 of 7
(450 Views)
Re: speed issue
21-06-2013 4:01 PM
In the meantime why don't you post the stats from your router - noise margin, attenuation and speeds - so we can see iof your speeds are about what you could expect
This explains how to get them http://community.plus.net/forum/index.php/topic,96155.0.html
Message 4 of 7
(450 Views)
Re: speed issue
21-06-2013 7:10 PM
Management and Diagnostic Console
System Summary
Broadband Link
• Summary
• Statistics
• Detailed Statistics
• Configure
Local Network
• Status
• Statistics
• Device List
• Wireless
• Configure
• Address Allocation
Firewall
• Settings
• Detailed Information
• Advanced Settings
Troubleshooting
• DSL Diagnostics
• Event Log
• Network Tests
• Upgrade History
• Resets
Advanced
• Syslog Settings
• Provisioning Info
• Configure Time Services
• Configure Services
• Static Routes
• DNS Resolve
• Traffic Shaping
• Link Manager
• Detailed Log
Troubleshooting – DSL Diagnostics
General Information
DSLAM: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 8128 kbps
Downstream Atten. at 300kHz: 69.8 dB
Uncancelled Echo: -14.3 dB Ok
VCXO Frequency Offset: 28.2 ppm Ok
Final Rx Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Impulse noise protection: 0.63
Delay of latency path: 4.00 ms
Training History
Downstream Upstream
Time Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn Attn Pwr CRCs FECs Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2013/06/16 03:43:10 BST 1 1472 1488 932 932 9.2 6.0 69.6 16.4 7356 3968627 0.63 4.00 448 592 10.0 31.5 11.9 1835 3731 G.DMT Annex A Alcatel 230/105 ERR_SIG_INTERRUPT -15.1 25.3 34.5 0
2013/06/20 05:46:30 BST 1 1600 1604 924 924 9.2 5.0 69.2 16.8 20304 3129347 0.58 4.00 448 596 10.0 31.5 11.9 628 2678 G.DMT Annex A Alcatel 230/105 ERR_LOS_LIMIT -7.1 28.5 34.5 0
2013/06/20 07:28:37 BST 1 1088 1100 884 884 9.1 10.0 69.4 16.3 6 67 0.63 4.00 448 592 10.0 31.5 11.9 0 12 G.DMT Annex A Alcatel 230/105 IDLE_REQUEST -11.8 28.3 34.5 0
2013/06/21 06:09:31 BST 1 1376 1392 1128 1128 9.2 9.0 69.5 16.9 430 13845 0.67 4.00 448 592 10.0 31.5 11.9 138 674 G.DMT Annex A Alcatel 230/105 IDLE_REQUEST -11.7 28.3 34.5 0
2013/06/21 19:02:46 BST 1 1472 1472 948 948 9.0 8.0 69.4 16.4 1424 104564 0.63 4.00 448 592 10.0 31.5 11.9 138 676 G.DMT Annex A Alcatel 229/103 N/A -14.3 28.2 34.5 0
Notes:
Time Time of last update
Max1 Max. rate at start of connection
Max2 Current or final estimated max. rate
Max3 Current or final estimated max. rate without INC
Mgn1 Noise margin at start of connection
Mgn2 Current or final noise margin
State Internal training state
Exit Code Cause of retrain
INP Impulse noise protection
DLY Delay of latency path
Bitloading
0000000455666677788777666554440000000068888775057778877777636666666666554444056567664455455452445545555554444423222033220002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
0 16 32 48 64 80 96 112 128 144 160 176 192 208 224 240 256
Message 5 of 7
(450 Views)
Re: speed issue
24-06-2013 10:35 AM
I've matched your profile to your sync speed so hopefully that will now help,
How's your connection on iPlayer and Skype?
Message 6 of 7
(450 Views)
Re: speed issue
24-06-2013 11:18 AM
Thank you, it is all much improved though I did switch off the routern overnight
1. Best Effort Test: -provides background information.
Download Speed
1.49 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.49 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Your DSL Connection Rate :1.82 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.5 Mbps
Message 7 of 7
(450 Views)
