slow upload- is this normal?
- Re: slow upload- is this normal?
20-09-2017 9:03 AM
Morning,
I just did a line test this morning.
Can anyone tell me is this normal?, it seems very slow speed.
My PC is always connected by ethernet directly into the router, which is about a foot away from the main box.
20-09-2017 9:08 AM
Welcome to the forums, @lollipop1 - that upload speed is actually very good for an ADSL connection, you would struggle to get very much more.
20-09-2017 9:12 AM
Thanks for your reply, maybe time to move onto fibre....
20-09-2017 9:23 AM
Check what you would get on fibre - if you really need a much higher upload speed and stay with Plusnet, you will need the 80/20 package, which is considerably more than you are paying for ADSL.
20-09-2017 2:56 PM
