routing problems over level3
- routing problems over level3
21-08-2013 6:23 PM
I'm getting connectivity problems to www.concrete5.org and running a traceroute to the server shows lots of weirdness going on once we get into level3:
[tt]
traceroute to concrete5.org (50.28.56.20), 64 hops max, 52 byte packets
1 192.168.2.1 (192.168.2.1) 1.476 ms 1.113 ms 1.046 ms
2 lo0-central10.pcl-ag04.plus.net (195.166.128.185) 48.198 ms 67.074 ms 76.158 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.174) 43.477 ms 41.596 ms 41.493 ms
4 206.core.access.plus.net (212.159.0.206) 43.583 ms 41.161 ms 41.067 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 42.163 ms 41.645 ms 42.131 ms
6 ae1.ptw-cr01.plus.net (195.166.129.0) 43.684 ms 41.531 ms 41.832 ms
7 217.163.45.181 (217.163.45.181) 42.252 ms
te-4-2.car5.london1.level3.net (217.163.45.249) 43.114 ms
217.163.45.181 (217.163.45.181) 41.331 ms
8 ae-52-52.csw2.london1.level3.net (4.69.139.120) 135.804 ms 131.442 ms 131.492 ms
9 ae-57-222.ebr2.london1.level3.net (4.69.153.133) 131.372 ms 130.716 ms
ae-58-223.ebr2.london1.level3.net (4.69.153.137) 130.877 ms
10 ae-42-42.ebr1.newyork1.level3.net (4.69.137.70) 146.644 ms
ae-44-44.ebr1.newyork1.level3.net (4.69.137.78) 132.425 ms 130.319 ms
11 ae-4-4.ebr1.newyork2.level3.net (4.69.141.18) 130.845 ms
4.69.201.46 (4.69.201.46) 131.199 ms
4.69.201.42 (4.69.201.42) 131.177 ms
12 ae-1-100.ebr2.newyork2.level3.net (4.69.135.254) 131.229 ms 131.232 ms 131.544 ms
13 ae-2-2.ebr1.chicago1.level3.net (4.69.132.65) 131.628 ms 131.595 ms 136.898 ms
14 ae-6-6.ebr1.chicago2.level3.net (4.69.140.190) 133.023 ms 131.262 ms 131.784 ms
15 ae-104-3504.edge2.chicago2.level3.net (4.69.158.13) 132.003 ms
ae-102-3502.edge2.chicago2.level3.net (4.69.158.5) 130.241 ms
ae-104-3504.edge2.chicago2.level3.net (4.69.158.13) 132.081 ms
16 cwie-llc.edge2.chicago2.level3.net (4.59.29.82) 132.105 ms 288.338 ms 172.939 ms
17 lw-core4-te91.rtr.liquidweb.com (209.59.157.206) 140.021 ms 140.496 ms 141.783 ms
18 lw-dc3-dist15.rtr.liquidweb.com (69.167.128.201) 139.983 ms 139.750 ms 139.944 ms
[/tt]
and no packets are actually getting there or back from www. concrete5.org
I had the same problem last night, but it cleared up this morning.
I haven't found any other machines with this problem and I can connect to other parts of the net fine, and my speedtest is giving me 3.5Mb/s which is great, and I've tried rebooting the router etc etc.
I can route easily from my server (not via level 3) and access the site so I think that it is purely a routing problem. Would anyone be seeing the same thing or have any suggestions?
[tt]
[/tt]
Message 1 of 7
(1,808 Views)
6 REPLIES 6
Re: routing problems over level3
21-08-2013 7:01 PM
What you described as routing weirdness could be nothing more than there being multiple different routes, unfortunately the routes might have slightly different numbers of hops, and mix together rather awkwardly when traceroute tries to display them all. The site loaded fine for me.
[tt]# traceroute -q 5 -N 1 -T -p 80 www.concrete5.org
traceroute to www.concrete5.org (50.28.56.20), 30 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 2.079 ms 1.841 ms 1.818 ms 1.792 ms 1.790 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 24.891 ms 24.107 ms 24.523 ms 24.807 ms 24.827 ms
3 link-b-central10.ptn-gw02.plus.net (212.159.2.142) 23.841 ms 24.267 ms 25.249 ms 25.278 ms 24.473 ms
4 xe-10-1-0.ptw-cr02.plus.net (212.159.1.46) 24.792 ms 25.694 ms 26.080 ms 25.755 ms 29.665 ms
5 ae2.ptw-cr01.plus.net (195.166.129.4) 23.824 ms 24.468 ms 24.480 ms ae1.pcl-cr02.plus.net (195.166.129.3) 24.849 ms ae2.ptw-cr01.plus.net (195.166.129.4) 25.006 ms
6 te-4-2.car5.London1.Level3.net (217.163.45.249) 24.332 ms 217.163.45.181 (217.163.45.181) 25.389 ms ae2.pcl-cr01.plus.net (195.166.129.6) 24.556 ms 24.679 ms 25.879 ms
7 ae-52-52.csw2.London1.Level3.net (4.69.139.120) 114.127 ms xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) 24.297 ms xe-11-1-0.edge3.London2.Level3.net (212.187.201.209) 24.404 ms xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) 25.487 ms ae-52-52.csw2.London1.Level3.net (4.69.139.120) 114.695 ms
[/tt]
Hop 5 in the above is 1 of 2 Plusnet addresses, hop 6 has some Level3 IPs but also a Plusnet IP.
[/tt]
Message 2 of 7
(627 Views)
21-08-2013 7:06 PM
I'm still getting timeouts on all pings.
However about 30m ago traffic did start flowing with a ping time of about 140ms. However, by the time that I had reloaded this thread to see if the traceroute had changed it had stopped working again and is still not working.
Message 3 of 7
(627 Views)
21-08-2013 7:09 PM
It does look as though Level3 is playing up
Tracing route to concrete5.org [50.28.56.20]
over a maximum of 30 hops:
1 82 ms 99 ms 99 ms 192.168.1.254
2 33 ms 46 ms 32 ms lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 32 ms 34 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.164]
4 32 ms 34 ms 32 ms 196.core.access.plus.net [212.159.0.196]
5 33 ms 32 ms 31 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
6 * 32 ms 33 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
7 122 ms 121 ms 122 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
8 122 ms 121 ms 133 ms vlan103.ebr2.London1.Level3.net [4.69.143.94]
9 122 ms 122 ms 121 ms ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
10 121 ms 121 ms 121 ms ae-4-4.ebr1.NewYork2.Level3.net [4.69.141.18]
11 124 ms 121 ms 122 ms ae-1-100.ebr2.NewYork2.Level3.net [4.69.135.254]
12 122 ms 121 ms 122 ms ae-2-2.ebr1.Chicago1.Level3.net [4.69.132.65]
13 122 ms 122 ms 122 ms ae-6-6.ebr1.Chicago2.Level3.net [4.69.140.190]
14 122 ms 121 ms 121 ms ae-102-3502.edge2.Chicago2.Level3.net [4.69.158.5]
15 274 ms 236 ms 208 ms CWIE-LLC.edge2.Chicago2.Level3.net [4.59.29.82]
16 131 ms 130 ms 130 ms lw-core4-te91.rtr.liquidweb.com [209.59.157.206]
17 131 ms 131 ms 130 ms lw-dc3-dist15.rtr.liquidweb.com [69.167.128.201]
18 129 ms 128 ms 129 ms community.concrete5.org [50.28.56.20]
Trace complete.
Trace complete.
Message 4 of 7
(627 Views)
21-08-2013 8:49 PM
It's strange that there's about 90ms added to the latency while still within London.
Message 5 of 7
(627 Views)
21-08-2013 8:56 PM
And stranger that there's zero latency added while crossing the Atlantic to New York! Or perhaps there's just something odd about where the latency shows up on the traceroute.
Message 6 of 7
(627 Views)
21-08-2013 9:04 PM
I can only assume they have server in new york specifically for receiving traffic from london.
Though a router in chicago has double the ping, but not the ones after, it's all very strange.
Message 7 of 7
(627 Views)
