Early connection possible?
haltdef
My modem has been syncing since we moved in, only PPP auth is failing - is it possible for my new plusnet account to be activated on the off chance my line is physically connected to the correct DSLAM? About to throw the 3G dongle into the sea!
Re: Early connection possible?
Only if BT have signed off on it, give them a call and find out.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
haltdef
Are plusnet staff able to see if my modem's auth requests are hitting their servers?
Fixes: 62
they are
The order has not completed yet, it is scheduled to complete on Wednesday 21st, if it completes prior to that we'll activate your broadband and let you know.
haltdef
It was worth a shot, thanks guys
Just to let you know your order is now complete so you should be able to connect.
haltdef
Oh, that's better! Thanks. Can I get my upload speed uncapped too?
Fixes: 64
Sure, I've just raised an order for that to be done tomorrow for you Smiley
 Adam Walker
haltdef
Thanks Adam
